Question about Kenmore Elite HE4 Electric Dryer
Getting the FH error message. have flushed the hoses, checked water supply and hose screens, unplugged it, etc. problem persists.....worked fine yesterday
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
I have code fh
Hey Lukec,
The FH error code on your Kenmore Elite washer indicats that there is a problem with in-coming water flow. When the water feeding the washer is less than what it should be, the FH code will trigger and the washer will shut down.
You can check a couple of common problems that can manifest this error code after resetting the machine. Steps for reset and diagnostics can be found below.
  1. Using the "Pause/Cancel" button on the washer control panel (this button will be below the digital time clock, to the lower right of the wash cycle selector) by pressing the "Pause/Cancel" button twice to cancel the wash cycle.
  2. Next, unplug the washer from the wall socket (this will reset the error code).
  3. Several things you can do to troubleshoot the follow issue are these:
    Check for kinks in the water supply hose.
    Turn off the water supply (hot and cold) and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  4. Reconnect the water supply hoses to the washer and turn on the water supply.
  5. Plug the washer cord back into the wall outlet.Select the wash cycle and press the "Start" button.
If the error code returns, you will likely have internal water flow issues due to the pump or other internal problems which may require a service technician.
Hope this helps.
Oct 03, 2014 | Kenmore Washing Machines
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
  • Apr 29, 2013 | Washing Machines
    HF Error Code on Whirlpool Washer. I am very handy. Have already checked hoses, pressure, etc. Have already unplugged for 2 minutes to reset, etc. Is there a dirty sensor, etc that I should look for?
    Hi
    Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
    Daniel
    Aug 24, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
    I have Duet front load washing machine and over the last 7-8 years have battled he FH code.I have opened the machine numerous times, tried to flush and back flush the water valves/solenoids gone back and...
    Hi
    Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
    Daniel
    Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Keep getting FH code. Have cleaned inlets and checked hoses. Water is coming in,sounds right but then goes to FH again.
    Hi
    Daniel
    Aug 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
    HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
    Thank you for contacting fixya.com.
    FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
    To clear the error please follow the bellow instructions:-
    Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
    Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
    Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
    Please get back to us if you have further query else please accept the suggestion.
    Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Washer flashing FH, first F, then H
    "FH" (Water Inlet Problem-no water or insufficient water
    supply)
    Select PAUSE/OFF twice to cancel the cycle. Unplug washer
    or disconnect power.
    Are water faucets completely turned on?
    Are screens at inlet hose connection to washer clogged?
    Are water inlet hoses kinked?
    Are water inlet hoses frozen?
    Also check the pressure hose for cracks or worn through spots, and pressure switch.
    May 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    I have an error message HF
    I suspect that you are getting the FH fault code that indicates a long fill on many of the Kenmore washer models. Here are some tips that might help:
    • If you are using a Flood Save device as shown in the image below for your fill hoses, this could be causing your problem. This type of device will not work on washers.
    • Make sure that the hot and cold faucets behind the washer are both turned fully on.
    • Turn the water supply faucet off. Disconnect the hoses from the back panel of the washer. Check the inlet water supply screens on the back of the washer. Clean any deposits and debris. Thoroughly flush this area with water to keep any debris from making it past the screens and into the inlet water valves. Debris can corrupt these valves and could cause them to leak.
    • Put the ends of the fill hoses into a bucket and briefly turn on the water supply faucets to check the water pressure and volume flowing through the fill hoses. If the pressure or volume is low, check the hoses for clogs. If the hoses are okay, then you will need a plumber to fix the water supply to the washer.
    • A failed water level pressure switch or flow meter could cause this problem on some models of Kenmore washers.
    • Check the installation of your drain hose. Make sure that it complies with installation guidelines. An improperly installed drain system can result in the siphoning of fill water through the drain during the filling of the tub.
    If these tips do not help, resubmit your question with additional details
    Dec 18, 2008 | Kenmore Elite 45986 Front Load Washer
    FH error
    You are correct..
    FH is an indication the the machine is not sensing enough water flowing into the machine....
    The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
    If screens appear OK then the problem may be with the water fill valve, water flow sensor, (flowmeter) water pressure switch or blockage in the water pressure switch hose.
    However.. if everything is fine using just cold, verify hot water for proper pressure or possible kinks in the hose.
    Jun 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite HE4 Electric Dryer Logo
    56 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Tim Whalen
    Marvin
    Marvin
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
