Question about Vacuums
I downloaded themes for my nokia 3500c from my pc. whenever i apply theme it shows 'unable to apply . Theme corrupted'. after that i updated my device software and formatted my memory card but still the same problem persist. HELP ME.
Some times its due to memory problem!
mean size of theme
Posted on Aug 10, 2010
  • Cbcavy Jul 10, 2011
    Mine 2, same problem. Its not memory size. Pliz help
Belts aren't broke roller still won't roll
Belt dosent have to be broke it may be stretched. It needs around 30lbs of pressure to roll the brush on carpet.
If it dose not roll off carpet at all the brush bearing are locked up. You may be able to remove the roller and check theme. Most likely you wil need a new roller brush.
Aug 08, 2014 | Bissell 8910 ProHeat Clear View Upright...
Hi, I have a Casio fx-115s scientific calculator which I've had for around 25 years. I am unable to use the bracket function and have lost the instructions. Could you please give any advice to save me...
You should be able to use parentheses in the same order in which you would write the arithmetic expression. For example, 4*(3.5-1.5)= should give you 8. Without the parentheses, this would 12.5.
Essentially, the left parenthesis comes immediately after an arithmetic operator, and the right parenthesis must close the parenthetical expression right after a number, and an operator must follow the right parenthesis.
Apr 23, 2011 | Vacuums
Where to download themes for samsung wave533?
go on enternet tool bar and put in download sale phone thems for free put mem chip in comuter then download them on mem. chip.
Feb 27, 2011 | Vacuums
I am not getting samsung corby mate themes how get then tell me theme is there or not
looks that this is not a vacuum. you are in the vacuum forum.
Feb 06, 2011 | Vacuums
Manual for Hoover DM6 197T/1 001
You can download your manual free from the manufacturer here:
http://service.hoover.co.uk/manuals/pdfs/DM6197T.pdf
Click the link and the file will open. You can then view, print and/or save the manual to your PC. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thanks.
Oct 21, 2010 | Vacuums
Hi! I am looking for a free unlock code for my Nokia 1661 mobile, from Entel Chile, IEME : 011884008602710. Thanks for your help !!
Dear Bro
I am also facing the same problem, whenever you get the solution please let me know.
Model : 1661-2
RH : 122
IMEI : 356940/03/708328/1
my email ID : asimch_83@yahoo.com
Aug 07, 2010 | Vacuums
Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Jul 05, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Feb 23, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
97 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
