Question about Viking VGSC366-6B Gas Kitchen Range
I have a Viking VGSC366 6B all gas range. The oven keeps shutting off when I'm baking somethimes for a long time. Sometimes i can turn it off and back on again but sometimes it won't come right back on. the repair guy is here now and doesn't know what to do.
When the oven igniter(s) get too old, they don't pass enough current to the gas valve to either open it or keep it open. If that's the case, they need replacement. They may still glow but they're no longer operating properly
Posted on Aug 30, 2010
2 Suggested Answers
Kgt1962
  • 59 Answers
SOURCE: Viking VGSC366 6B oven door won t open fully
Sounds as though the hinges are broken. Door will have to be removed and hinges replaced
Posted on Mar 08, 2009
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Lp gas double oven gas bake valve
i believe your problem has been the ignitors the whole time . make sure you are getting the viking factory parts for the ignitors its a part #PB040001 it should come in a small factory box with the part # on the box
Sep 27, 2008 | Viking VGIC485-6G Gas Kitchen Range
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Oven gas does not come on?
It sounds like a bad glow plug.It may also be a bad ignitor box!! I would check the glow plug before i would suspect the ignitor box.It's alot cheaper!!
Dec 04, 2007 | Viking VGSC306-4B Gas Kitchen Range
Viking VGSC366-6B Gas Kitchen Range Logo
269 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
