Question about Brother HL-2040 Laser Printer
All the light flashing - Brother HL-2040 Laser Printer
  • 2,272 Answers
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 02, 2010
Abs flashes on and off on dash then brake light flashes on and off brake lights flash when dash lights flash
dashboard brake light flashing randomly - Forums.focaljet.com
forums.focaljet.com/.../662231-dashboard-brake-light-flashing-randoml...
May 14, 2012 - 12 posts
Car run great the only issue is the dashboard brake light is flashing randomly. ...Finally, the instrument cluster is hardwired to the ABS module, ... Also,i change the parking brake switch and the light goes on & off less frequent.
what does ABS flashing light mean at the dashboard of my 1996 ...
https://answers.yahoo.com/question/index?qid...
May 3, 2009 - What does ABS flashing light mean at the dashboard of my 1996 ... just hard enough to skid a tiny but, then back off a hair to stop skidding.
ABS Brakes Troubleshooting - How to Troubleshoot Anti ...
www.popularmechanics.com/cars/how-to/a461/2265091/
Jan 30, 2016 | Cars & Trucks
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Mar 06, 2011 | Health & Beauty
Check engine light is on check engine light
Take the vehicle to Auto Zone, advanced Auto parts or o'Rieley's Auto parts and ask them to use their scanner to read the stored Code from the ECM for you.
Jul 14, 2010 | Cars & Trucks
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Beginner with Studio Lights
will need more information, but the basic idea is to connect the trigger on top of your camera's hotshoe, and then connect the receiver to the flash.
Feb 11, 2008 | Cameras
Brother HL-2040 Laser Printer Logo
379 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
