Question about Canon PIXMA MP620 All-In-One InkJet Printer
Getting a 6C10 error constantly and I am unable to use me printer (Canon MP640). What shoul I do?
    Scholar:
  • 37 Answers
First thing try removing the paper out of the top tray and put it down to the bottom tray only. When its opened it might work (even if no red lights and not aligning to the middle) if you just manually push it side to side over and over again so it can get the back rail lubricated and start to move on its own. Try turning the printer off and on with the whole head open when you can see the ink cartridges. If that doesnt work alone try pushing it back and forth to lubricate the rail in the back and re- turn it on and off again with it open
Posted on Aug 02, 2010
PIXMA MP640 6C10 fout
You need to replace the ink absorber and reset the error code by following the reset procedure:
Resetting error 6c10
Dec 23, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
6C10 error cannon printer MP640
This error could appear on these Canon Pixma printers: MP110, MP540, MP630, MP620, MP640, IP3600...
Solution 1:
  • Move the printhead to the center.
  • Disconnect the printer and check on the right: is the purge unit ok ? No peace of paper ?
Solution 2:
  • Do a reset of the printer:
  • Power on
  • Hold down the "Resume" button (triangle in a circle) for 15 to 20 seconds.
Solution 3:
  • Power off the printer.
  • Open the door.
  • Power on.
  • When the cartridge is in the center, close the door.
Solution 4:
  • Open the lid and allow the ink cartridge carrier to center itself.
  • Looking to the right, you will see a row of white rollers behind the carrier.
  • At the end of the rollers there is a small, clear piece of plastic that sticks up. Take a small piece of a paper towel and wipe all of the ink off this piece of plastic. When that is clean move on to the ink pad.
  • About 1 inch, towards the front of the printer from that piece of plastic, is a small square, about 1/2 inch per side, that is a small foam pad. This is where the excess ink is collected.
  • Take a piece of paper towel and press into the foam. Do this until the paper towel is no longer collecting ink. Close the lid, turn off the printer then turn it back on.
source: http://fix-your-printer.blogspot.com/2011/06/how-to-fix-error-6c10-on-canon-printers.html
Jul 04, 2012 | Canon MP640 All-In-One InkJet Printer
Printer error 6C10 canon mp640
This error refers to a problem with the valve cam sensor and is usually associated with some material probably paper jammed in or around the purge unit.
Turn the machine on and when you hear the motor start pull out the mains plug. open the unit and push the carriage to the left end of its travel. Shine a torch into the right end of where the carriage normally parks and you may find some paper stuck on or around the purge. If nothing then gently push the white arm back and forth in case it has stuck. Hopefully that will cure it. if not then a new purge unit is required and thats a big job for a canon repairer to do.
Good luck.
Jun 27, 2011 | Canon MP640 All-In-One InkJet Printer
Canon MP640 has 6C10 error, I have used the service mode and restore button x4 to reset absorber counter, but this stops the error until you go to print - then the next document returns the same 6C10 error...
my canno mp640 will not print in black, have replaced the 521/520 carterages new also a new printhead, and stiil it will not print,yet it prints colors ok. can you help please
DD.
May 12, 2011 | Canon MP640 All-In-One InkJet Printer
My printer is only 5weeks old / installed end of March and i have this error message on the display screen 6C10 I have tried ti turn the printer off and back on again but the error still occurres. Do...
This error is caused when the ink absorber has got full and needs to be replaced.
This is something you can get done by a local service centre or a Canon service centre.
Andy
May 02, 2011 | Canon MP640 All-In-One InkJet Printer
My printer MP640 got message as 6C10 , i had follow the instuction in you solution but they do'nt work , do you got other way . Thanks
Hello and Welcome to FixYa
Error 6c10 is ink absorber problem.You need to reset Printer Canon ink absorber. Follow the steps given below
  • Start with printer off
  • Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  • While holding the Power button, release the Resume Button.
  • Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  • Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  • Turn off the printer and turn on again
Error will be removed
Anymore help, I am here to help
Thank you for using FixYa
Mar 17, 2011 | Canon MP640 All-In-One InkJet Printer
6c10 errror message on canon mp640, tried suggested moving of printcartridge holder, no go. Any suggestions?
Hi, I solved this by doing a "cleaning roller" (dont know the right word in english) from the settings -> maintenance menu of the MP640. Good luck!
Oct 24, 2010 | Canon MP640 All-In-One InkJet Printer
Hi Guys...I have a MP640 which is showing a 6C10 error...Please Please Help...I have soo much work to do that is pileing up....
Hey you, I solved this problem by doing a "cleaning roller" (dont know if this is the right english term) for the paper cassett. You can do this via the settings -> maintenance menu of MP640. Best regards!
Jul 30, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Canon PIXMA MP620 All-In-One InkJet Printer Logo
839 people viewed this question
old marine
old marine
