SOURCE: lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
SOURCE: lg plasma tv 42pc3dv
you will have to have a tech come check that one out, your gonna need your y-sustain, z-sustain and both y-drive boards replaced.. its a common issue try to get your warranty extended if its out.
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
SOURCE: The screen on my 4 yr old 42 inch LG plasma keeps
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
