Question about Craftsman Garden
The fuse blows when you turn key on - Craftsman Garden
  • 760 Answers
Ok you didn't list any model or brand, but typically you have a short, which means some electrical device is grounded, and so when you turn the switch on, it blows the fuse. Now is it when you turn the switch on? or when you turn it to start. If it is just when you turn it on, then typically the only things in circuit are the Fuel shut off solenoid (if it has one) hour meter (if it has one) alternator. You can follow the wiring, and look for bare wires, and then disconnect each device one at a time. If it blows when you try to start it , then it could be in one of the safety switches such as clutch pedal, clutch control (relay or switch) or even the starter solenoid.
Posted on Aug 02, 2010
TURN KEY BLOWS FUSE RIGHT AWAY
There is a short to ground causing the fuse to blow. Trace all wires from IGN and look for one that may have been damaged.
Jun 17, 2015 | Garden
There is no reaction when turning the key to start the car
Turn key to On.
Turn on headlights manually... Do they come on?
Are there any lights on the dash?
If yes to these, battery is possibly not the sole problem.
Check for good, tight and clean connections at battery terminal posts!
If yes to above, continue on & get a helper... Turn key past on, to Start position.
Do you hear a click sound at time key is turned to Start?
If yes, then ignition switch is not problem, starter relay is getting power, and is now sending power to starter, but starter is not working.
Pic any No's... Then look there.
Good luck.
Mar 29, 2015 | 2005 Ford Focus 1.6
Ford 99 Taurus ignition fuse keeps blowing every time key is turned
A bad something, yes.
The fuse may be the primary fuse for the key switch. If it is, you would need to disconnect the key switch harness and check for a short to ground on each circuit.
Jun 01, 2013 | Ford Cars & Trucks
30 amp Starter/Ignition fuse keeps blowing when i turn the ignition key. The instrumentpanel lights are dim and then the fuse blows.
I am assuming you are talking about the circuit that powers the key switch. I'm showing a fuseable link to the starter relay instead of a fuse.
If it is the circuit that powers the switch, I would disconnect the switch and see if the fuse blows as each circuit is powered one at a time using a jumper wire. You can get 30amp circuit breakers that plug into the fuse slot to use while you are testing circuits.
You may need a repair book or shop manual to find out what is powered by that fuse since it is most everything on the car.
Mar 01, 2013 | 1997 Dodge Avenger
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 05, 2012 | 1999 Chevrolet Prizm
20 amp fuse keeps blowing engine won't start, fuse
I am a mechanic,i had that same problem where my engine 20amp fuse were blowing....i fixed it...problem were a broken wire in the harnace on the side of the cylinder head....i made over $200 on that job...yahhh
Aug 01, 2011 | 2001 Mitsubishi Galant
Every time I turn the key to start the motor it blows the 30 amp fuse what is the cause and how do I fix it
if the fuse is blowing when you turn key to start position then this is where to look for the fault ,between the ignition switch and the relay then the other side of the relay to the starter motor solonoid
Mar 05, 2011 | Ford Focus Cars & Trucks
I have a 1986 Corvette that blows the 10amp fuse for the fuel pump. How can I determine the cause?
If the fuse blows after turning the ignition key to the "on" position you might try disconnecting the electrical connector to the fuel pump and turning the key to the "on" position. If the fuse still blows there is a short in the wiring to the fuel pump. If the fuse does not blow it is more than likely the fuel pump.
Jan 27, 2011 | 1986 Chevrolet Corvette
Garden Logo
160 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
