Error code f35-6 on konica 7145 copier
Every time i try to turn on this machine,displays this error code,and i can't do anything because of this f36-5 error code.i will be so greateful if you can assist in eradicating this nightmare
  • brian c
    brian c May 11, 2010
    F35 is a fuser unit error / failure.
    What is the print / copy count?
    Problem Solver:
  • 6 Answers
Replace Thermo- fuse (open ) fuser not getting to 160, and clean thermister, toner builds up between roller and thermister causing overheating of fuse to blow .
Posted on Apr 25, 2008
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
I have a Konica 7145. It has error code
This is a fixing unit over temperature fault. The device has detcted the fixing unit has gone over 470 degrees F.
You will need to check the Thermisters in the fixing unit, and repair or replace as needed.
Service mode DIP Switch needs to be reset after repairing.
WARNING
• When F34-∗∗, F35-∗∗ or F36-∗∗ (fixing temperature related abnormality) occurs, be sure to repair a defective part before setting the 25 DIPSW 3-1 to 0.
If the 25 DIPSW 3-1 is set to 0 without repairing a defective part, it may cause a fire.
Apr 26, 2010 | Canon imageRUNNER C3200 Copier
Error code F-35-1 in bizhub 7145 copier
quote is probably in the right price range. you need to look at how many copies are on your machine. look at any future repairs/supplies that will be needed. like drum, developer unit. If these are also needing to be changed soon, you will have to plan on those costs also. Any comparable machine that you get get will be expensive to repair the big items. You have to put all of the money that you spent on the machine and find out how many copies you have made. you can then figure out the cost per copy. At the same time, if this machine does everything that you need from a copier, do you want to buy a new one at much higher cost.
Oct 13, 2009 | Toshiba E-Studio 3511 Color Copier
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
Konica 7145 Fuser Error F34-2
You could go into service mode and reset error count normally to get into the service mode is the following depending on age of machine.
Thanks Jason
A. Procedure
1. Press the Utility/Counter key.
2. Touch [Details] on Meter Count display.
3. Press the following keys in this order.
Stop → 0 → 0 → Stop → 0 → 1
Aug 16, 2008 | Office Equipment & Supplies
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
237 people viewed this question
jasbo
jasbo
