Question about Sharp AR-235 Copier
I'm getting an E7-10 error message on my copier
    President:
  • 2,072 Answers
10 Content CCD black level error
Details CCD black reference plate scan level
abnormality when the copy lamp turns off.
Cause Flat cable installation failure to CCD unit.
CCD unit error.
Check
and
remedy
Check flat cable installation to the CCD
unit.
Check CCD unit.
Is your lamp coming on? If so most likely the CCD assembly needs replaced, That would require replacing the carriage that contains the lamp and mirrors, the CCD is mounted to that and is laser adjusted at the factory.
Posted on Aug 02, 2010
I get a message 'print cartridge error'. nothing
Try replacing the cartridge, if still getting error cleaning contacts in printer where cartridge sits with wet Qtip, also clean printhead on cartridge. Reinsert cartridge and see if this clears error message.
May 31, 2010 | HP Officejet 5610 All-In-One InkJet...
Error message on copier ar 160 L 6
polygon motor lock detection
Feb 15, 2010 | Sharp AR-160 Copier
Canon Copier error message
There is a fault associated with the drum/developer
Jan 14, 2010 | Canon imageRUNNER C3200 Copier
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
Minolta di1610 error message
What error message? Does itsay toner cartragie need replaced.
Apr 04, 2009 | Konica Minolta Di1610 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Oct 04, 2007 | Panasonic Workio DP-150PA Copier
Sharp AR-235 Copier Logo
276 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
