Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
This is an external hard drive that I have not used for a couple of years. My computer which it worked with before (an HP Pavillion) does not see the external hard drive and while the light on the hard drive is on, there is no sound from the drive.
  • mmcgloin Aug 02, 2010
    Not a fix, but I'm quite sure an accurate analysis.
    President:
  • 4,070 Answers
Hi! Please try replacing the usb cable. The cable may be corroded causing the external hard drive not to be detected by the pc. Hope this helps and have a good one!
Posted on Aug 02, 2010
  • 3 more comments
    I replaced the USB, no luck.
  • dj_relly999
    dj_relly999 Aug 02, 2010
    How bout connecting it on a different usb port. Try using the rear usb port and see how it goes.
    Already tried that, and tried with a different computer as well.
  • dj_relly999
    Ok, I believe that the hard drive reached its break point causing it to fail. I guess its time to purchase a new one.
  • dj_relly999
    How I wish I can revive the hard drive to save you some money but I guess it reached its time.
External dvd/rw drive wont play on my hp pavillion chromebook
Make sure the USB port(s) are in working order. Check them by using Device Manager? Then check to see if the drive is visible in My Computer?
Jan 12, 2014 | Pc Treasures Digital Treasures External...
Clicking noise, won't mount
the controller on the external drive could have gone bad. i would first try removing the hard drive from that external enclosure and use a usb or esata dock and see if itll mount.
Nov 26, 2013 | Fantom Titanium Hard Drive
My HP Pavillion DV2500 laptops USB Port is receiving low power and thus not allowing me to read an external Hard Disk
Does your laptop have a USB port with a little plus icon near it? (+). If so, try using that...
Mar 17, 2013 | HP Pavilion Computers & Internet
My computer (HP Pavillion p3101) won't see my external Calvary drive (500 gbcaue37500) It worked a few times and now I can't access it.
Press the start button and right click "my computer"-> Manage -> Storage -> disk management. It can take up to a minute before displaying your discs. Rightclik your 500 gbcaue37500 and and depending on what's avaible;
Change from offline to online
initialize
Assaign a drive letter to the drive
  • If my solution helped, feel free to rate it!
Jul 30, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Have an HP pavillion A1540n. after power up, get screen with "Hard disk failure imminent' "Backup files. replace Hard drive." I'm not able to get out of this screen unless I power down the computer. I have...
Sometimes it is easier to install a new hard disk and reinstall Windows.
Then either connect the old hard drive as a slave drive (don't forget to set the jumper on this drive as a slave). The other way is to connect the old hard drive to a USB hard drive adapter and connect it to a working computer's USB port. this computer will see it as an external hard drive (provided the hard drive is still functioning).
Either way you can download and backup your files.
Nov 02, 2009 | HP Pavilion a1540n PC Desktop
My computer is not recognizing my acomodata external hard drive
Can it work in another port or another computer?Try these option if all fails maybe the device is bad.
Oct 02, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
HP Pavillion Desktop no internal speaker?
No it won't. You will have to go out and buy external speakers.
Jun 15, 2009 | HP Compaq Computer Speakers
Transfer data from a dead laptop to a new laptop
Do you have a usb to SATA connector? If so you can plug the old drive into the USB slot and it will act as a slave so you can pull the contents from the old drive to the new. The adapter is about 25.00 or If it was me I would invest into a pocket USB hard drive case that you can put your old drive into perminatly so you can always have a external hard drive for back up later after yo uhave moved the data over and reformatted it. The case is $25-$40.00.
Joe
Jan 16, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Black screen for hp laptop
Initially, a couple of ideas ou may want to explore:
  • hook an external monitor. Often there would be a VGA connector at the rear of a laptop specifically for this purpose. It would need a standard 15 video cable normally attached or with the external monitor. You may need to cycle through Fn + F? keys to enable the external monitor. F? would be the function key with the small monitor icon;
  • remove the hard disk of the erring laptop, connect it to a 2.5 to USB adapter and attach to a free USB port of a 2nd computer. it will be treated as an external storage device much like a thuimb/flash drive and therefore would allow copy and paste;
  • tap on the cover of the laptop, the one right behind the LCD screen anywhere on the sides, this is in the hope that it is a cold solder or loose connection;
  • run the laptop with the lid not fully opened;
  • slightly warp/twist the lid/LCD, it could just be a loose connection;
  • if the display works even just momentarily, then chances are that no major repair work is required. The bulk of the job would be in the opening and offhand, no major component replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | HP Pavilion dv4000 Notebook
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
42 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
