Question about Acer Aspire 5500 5570-2609 Laptop
Acer 5570 bootmanager missing,cannot boot from recovery cd always show bootmanager missing
JSGRepair
  • 130 Answers
SOURCE: acer e-recovery problem
The e-recovery software is used to access the 10GB hidden partition on the original drive, for recovery. Therefore a new drive doesn't have the 10GB Backup files for the system. Since the hidden drive is not there, the software can't access the hidden partition, therefore, the software will not install because there is no need for it.
If you need more info, please e-mail me,
Thanks, Have a nice day!
Posted on Jan 03, 2009
shahabdun
  • 249 Answers
SOURCE: VISTA boot stop and shows ACER recovery screen .
Restart PC
Press F8 as it restarts.
Select Safe mode and see if it workes.
Restart PC again.
Select "Last known good configuration"
If this does not work either,
Do a system restore.
Posted on Jul 19, 2009
Geekman
  • 32281 Answers
SOURCE: acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Posted on Aug 15, 2009
myrlex
  • 674 Answers
SOURCE: my acer aspire 5315 always show boot prepare os.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Posted on Dec 30, 2009
  • 188 Answers
SOURCE: Hi, After switching on the
The bets way is to restore the computer to the factory settings.. So that the issue will be fixe.. follow the steps
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Posted on Dec 14, 2010
Emachine w3619 bootmanager missing
the tray can be damaged or if it is not lit at all it has no power or is corrupted..if it is just jammed ..you can try to insert a sharp object into the hole on the tray and push to manually open it and see whats the problem ..
About the boot manager ..it either has a unplugged cable in the hard disk area..and it sees no boot support ..or the operation system is corrupted and you have to reinstall it from the disk or use the recovery partition if it has one ..
Dec 17, 2011 | E-Machines Computers & Internet
Bootmgr is missing
Bootmanager is the "program" that makes the computer able to load operating system.
If this is missing your pc won't boot up.
To solve this issue you should use the windows installation cd and install it again
Beware not to format your hard drive otherwise you will lose all your files.
Let us know if you solved your problem
Aug 21, 2011 | Acer Computers & Internet
Acer aspire 4736z with window 7 os had its bootmgr compressed... the screen keep showing "bootmgr is compressed press ctrl alt del"
Boot to the Windows Recovery Environment (WINRE) for 7 and run the following commands from the command prompt:
c:
cd \windows
cd system32
compact /u c:\
compact /u c:\*.*
x:
bootrec /FixMbr
bootrec /fixboot
bootrec /rebuildbcd
exit
This will resolve the issue as the boot loader will no longer be flagged to be compressed, will uncompressed, and then rebuilt.
Mar 21, 2011 | Acer Aspire 5500 5570-2609 Laptop
My accer 5315 says bootmanager missing whatcan i do without disk
you will need to re-install to factory settings right after the bios boots press f10 or f11 and it will enter recovery mode hope that helps. let me know!
Mar 17, 2011 | Acer Aspire 5315 Notebook
Acer aspire one error in oxf0000005 / NTLDR is missing
That is a windows error. You can try booting off the original installation CD and choose option for fix current installation, but chances are 50.50 if it will work or not. NTLDR is the bootmanager for Windows NT based systems (Windows NT, 2000, XP, etc). Critical system file, typically protected against altering.
The error code you gave is usually associated with windows having issues seeing / using a SATA drive. You will likely have to find the driver for our particular SATA controller, and load it when prompted as you startup off the recovery disk.
Jun 22, 2010 | Acer Aspire 5102WLMi Notebook
Bootmgr is missing
what happened is u accidentally have deleted ur bootmanager or bootloader or OS loader(all means same) file from ur computer's C drive ... what u would need is a boot loader software and u may search the web for possible solutions... u may also try to use ur recovery disc and try ur luck....
The boot manager or boot loader is what tells the computer brain what OS is loaded in ur computer and which OS to use to interact with u....
Jun 15, 2010 | Acer Aspire One AOA110-1113 Netbook
Unable to load windows
Here's a guess:
Missing NTKNRL>EXE or
Missing BOOT>INI
if it IS OS related. If it is hardware related then perhaps re-post.
(...a disclaimer though) My OS is W2K My only other OS is Seven. A quick google showed nothing but complaints about your machine. Same result when google my Acer so...
You have the manual from site?
Feb 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Missing bootmgr
something has removed the bootmanager from your harddrive your going to need the windows cd, you can try useing the repair console to restore the bootloader, also you can try a repair install or a fresh windows install.
Mar 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
5520 acer
try the f10 or f12 recovery option, manufacturers rarely ship the laptops with disks these days, and there should be an option on boot to make the cd's that you need. If not- you will have to contact acer and ask them how to make the recovery/boot cd's
Nov 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
224 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
