My teco split air-conditioner won't switch off. All the buttons on the remote seem to be working, except for the on and off button. How can switch it off manually without using the remote? It's very late and I cant get anyone in at this time to try and fix it. Please help.
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Posted on Mar 16, 2008
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
I want to locate a Eolia West Point A/C remote
Posted on Oct 23, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
My exprssion mini split a/c has switched off and only goes on if you use the override switch inside the unit and will not operate with the remote any longer - it went off after my nephew put it on and kept...
The remotes for the mini-splits send very complex digital codes each time you press a button. If the batteries are not working at nominal voltage the remote will not send the signal correctly even though the screen seems to work fine. Try switching out the batteries.
Sep 04, 2011 | Carrier 38BRC036 Air Conditioner
I think my problem is with my remote - I dropped it and nothing seems to work right. Where can I get a new one Is there another way to operate the unit if the remote goes down
what buttons do you have on the indoor unit just an on/off button . have you tried taking battery out then putting them back in. you can get a universal tv remote which also does air cons
Nov 08, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Auto delay on splits
All Split ac units have a safety system in them for a smooth switch over.
The delay time is different in all units especialy if they are "Inverters" or "soft start"
To be extra safe , just select prefered Temp and then Put it all on Auto.
Also some models have an anti tamper lock on the remote settings.
Feb 02, 2010 | Heating & Cooling
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Mar 01, 2009 | Heating & Cooling
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
235 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
