Question about Sony Cyber-shot DSC-T10 Digital Camera
Hello hi my xbox 1 not 360 is saying that it needs to be serviced but i dont know the service number and it also flashes a red led please help cheers jayme
  • 4 Answers
That sucks. It may be caused by an overheated motherboard. it happened to mine. I just got a new one. invest in a new one. sorrry
Posted on Jul 24, 2009
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
Dec 12, 2010 | Microsoft Xbox 360 Console
Sound, no picture, Red LED 4 flashes
Hello Thanshar, Hi, you TV has sound, but no picture. this could be several things, and let us add the red led flash. In my analysis, no picture means no high voltage is reaching the picture tube. this could be due to a bad Horizontal output transistor, and/or a bad flyback transformer. This bad transistor is causing an overload to the power supply section, causing the 4 led flash to blink. Now i want to know if you want to do this service or get professional help. if you decide to do this by yourself, this needs to be performed: the Horizontal output transistor must be checked for short, the horizontal flyback transformer needs to be tested, the deflection yoke also needs to be checked, especially to horizontal coil.
Oct 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Dec 21, 2008 | Microsoft Xbox Console
Was playing Tiger Woods 09 on my 360 when the graphics all of the sudden looked very cheap and generic. I played a few more holes and then shut it off. I tried to turn it back on after about 5 minutes and...
Sounds like the infamous Xbox 360 "3 flashing red LED's" issue, ours did the same shortly before suffering 3 flashing red LED's. If you have one of the original Xbox 360's (without an HDMI port on the back) every single one was built with the wrong solder, so when it gets hot enough the solder melts and your graphics chip gets disconnected.
Is mad as it sounds, run the Xbox 360 for a bit longer until it dies completely because Microsoft have extended the warranty for that specific issue to 3 years! Once you have 3 flashing red LED's you can call the help-line in your country, go through a few diagnostics with them and then (and only then!) the call agent will tell you that as long as your Xbox is less than 3 years old it will be repaired for free.
Microsoft have not widely advertised this and indeed if you try to book service on line it will tell you that you have to pay, even if you click yes to the question "Does your Xbox 360 have 3 flashing red lights on the front?".
However, if you have a newer Xbox 360 message back and we'll go through further diagnostics.
Nick. :)
Nov 06, 2008 | Video Game Consoles & Games
My original xbox turns on but then it says it needs to be serviced and then flashes red what could this be
another question not being real specific? why dont you post the actual error code given, and anything you may of done before this happened.. sorry i cant help. provide more info and i can help ya...
Oct 13, 2008 | Microsoft Xbox Console
Red light on original xbox suggestn servicing required
I can help you fix your xbox but i need the service code number in the top corner of the screen suggesting servicing. You can email me at
Aug 26, 2008 | Microsoft Xbox Console
How do I Fix flashing green and red light
What error number does it have on the screen? It should be a white number in one of the corners of the screen. If you find out what it is, then select add more details in this question and say what the error number is.
Dec 22, 2007 | Microsoft Xbox Console
got to e bay theres a guy on there selling plans on how to fix the three red lights will save u a lot of money as u wood have to send back to microsoft 4 fixing and its about £25 p&p the the repear on top then p&p back to u hope these helps e mail me if u need more info thanks
Dec 01, 2007 | Microsoft Xbox Console
Sony Cyber-shot  DSC-T10 Digital Camera Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
