I need the wiring diagram for installing a capacitor to my air conditioner for my house. can you help
  • 857 Answers
The instructions that come with a starting capacitor are simple enough that they are often printed right on the capacitor itself. But be careful, failing to turn off electrical power, and failing to discharge a capacitor when working on electrical equipment can result in a nasty or even a fatal shock. See our motor starting capacitor safety warnings just below.
The particular starting capacitor to be purchased is matched to the horsepower range and voltage of the compressor or motor being repaired. Many motor starter capacitors to support a pretty wide range of motors. For example our sample capacitor was rated for use on 115V electric motors rated from 1/12 horsepower to 1/2 horsepower.
Prices for typical air conditioner compressor starter capacitors range from around $10. to $50. U.S.
Here are some sample capacitor installation instructions for adding a motor starter capacitor to an air conditioning compressor motor - taken from the product package for a relay and start capacitor intended for use on a refrigerator or freezer. Similar starter capacitors are available for air conditioning compressors.
Remove the power supply cord from the electrical outlet - in other words, be absolutely certain that electrical power has been turned off to the equipment being serviced.
Remove the old starting relay, leaving the old overload protection in place.
Push the wire with the one single pin terminal onto the "start" terminal of the air conditioning compressor. (See the wiring diagram above).
Push the other wire with the pin terminal onto the "run" terminal of the air conditioning compressor.
Connect the line from the old starting relay to the spade terminal on the "run" wire (insulating sleeve).
Restore electrical power
Air Conditioner Motor Starting Capacitor Safety warnings:
When testing a compressor, one must discharge the capacitor first! It'll otherwise have enough power stored on it to be at least very painful. (Author and others have been zapped!) Some systems will automatically discharge the capacitor, but shorting its leads with a screwdriver (after verifying that the power's off) is a safe way to ensure that you won't get shocked. Motor starting capacitors can hold a charge for days!
If oil has leaked out of a capacitor: Don't touch any oil that leaked out: old capacitors may contain PCB oils, an extremely carcinogenic (cancer causing) material which require special disposal.
Once the capacitor has been discharged (as described just above), then it can be tested with a multi meter. Either use the meter's built in capacitor test function, or use this trick: Charge the capacitor by using the sense current the meter puts out when set to ohms. You should observe a rapidly rising resistance before the meter indicates over range/infinity. Disconnect the test leads, and switch over to volts. Then, reconnect the test leads. A voltage reading should be observed, approaching zero.
If the capacitor doesn't hold a charge, or the resistance reading never approaches infinity, it probably needs replacement.
Also, the capacitor may be defective if the compressor hums but does not start. Visual inspection may reveal it to be bulged, or have a blown out safety plug.
For diagram go to this link
http://www.inspectapedia.com/aircond/Capacitor_Starting640-DFs.jpg
Posted on Aug 02, 2010
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Air Conditioner comes on but outside fan wont start unless I manually start it....how do i replace capacitor and how would I know if it is a capacitor issue? Please Help
First mark the wires and make a diagram so you can reconnect it. Next remove the capacitor. You can take it to a heating and air supply and they will test it for you. They will also sell you a new one. Use your wiring diagram to reinstall the capacitor wires. It sounds like your problem is the capacitor.
Aug 02, 2010 | Heating & Cooling
Ive installed a new capacitor on my 3ton unit,now the breaker keeps flipping.I think i may have my capacitor wires cross! please help!!!!!!!
A cap for just the comp, one wire form the contactor to the cap and the other wire to the comp, there should be a wire diagram. if it is for the fan and comp it will be lable fan,com,comp. one wire3 from the contwctor to common, the fan wires one to common and on to the fan side. The last on for the comp
Jul 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Hi there, few days ago my HAIER 12,000 btu, ESA3125 died. it smell like burning wires. after i disconnect it from the wall and after putting my rubber gloves i open the case that holds the circuit and...
You should be able to take the information you have (on the capacitor) to Air Conditioning Supply House and purchase an exact replacement.
As to the diagram. There should be a schematic on the unit - somewhere. Usually located on an 'inside' panel.
Unless someone has removed it - the AC will have a schematic on it.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
The AC unit outside is running but the fan is not moving at all....The air coming into the house is not cold at all. Is the problem a bad capacitor? If so can I fix this myself? To be safe, will turning...
Could be a bad capacitor however, it could be a bad motor. (make sure you have disconnected the power from the unit ) The cheapest and quickest way to see is to get a capacitor and install Once the new capacitor has been installed if the fan doesn't activate then fan motor is also bad. The capacitor is a round or oblong and it is either silver or gray If it is a dual capacitor it will also connect to your compressor. There will be several wires coming out of it follow the brown or yellow wire from fan itself to the capacitor If it is a dual capacitor it will also have wires coming from the compressor to the capacitor. Make a diagram of the wire placement on the capacitor before removing to insure you place the correct wires back to the correct location. VERY IMPORTANT. Thiis capacitor will have voltage stored in it even though you have disconnected the power so make sure that nothing comes in contact with both prongs i.e. touching the prongs to metal together on th a/c unit while removing It will give you quite a jolt. Take the capacitor to an appliance warehouse for replacement to insure the proper capacitor is given to you. Hope this helps good luck on your repairs If I have helped you let me know
Dave
Sep 16, 2009 | Heating & Cooling
Need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Jul 03, 2009 | Emerson Quiet Kool 10MW42K Air Conditioner
Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
May 12, 2009 | Heating & Cooling
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
Heating & Cooling Logo
265 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
