Question about Asko D1796FI Built-in Dishwasher
My Asko dishwasher is not producing water
My dishwasher has water flow through the bottom, but apparently not the arm. It gets very hot through the cycle. What to do???
  • Asko Master
  • 2,605 Answers
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Posted on Aug 02, 2010
I have been in my house for 7 years and only ran the dishwasher about 4 times. Decided to use it today, nothing but a loud noise, no water. Is it clogged? If so, how do I fix it? It was brand new with the house. Had't turned it on in 2 years. Help!
Posted on Jul 30, 2011
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
ASKO 1905 ARMS NOT SPINING
Is water flowing, ie pump activated. if you can remove the arms, check the seals are clean. Check to see if the arm is hitting anything by spinning by hand before cycle. Also remove arm and check to see if nozzles are blocked, sometimes you cant see the blockage as the blockage is further inside the arm. Use tweezers to remove anything. Bottom arm could be inhibited by missing roller on rack also
Apr 20, 2014 | GE 24 in. GLD5500L Built-in Dishwasher
Asko dishwasher top wash arm washes. The bottom wash are does not more.
More often than not on Asko dishwasher the lower spray arm or filter will clog up causing this issue. The filter in the bottom twist out for you to clean. Check the lower spray arm holes they to will come clogged causing this issue.
Appliance & Refrigeration Repair
Mar 24, 2011 | Dishwashers
Water pumps into the bottom of the dw but the spray arm doesn't rotate and spray. It also empties, so the problem seems to be with the spray arm. Any solutions?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 04, 2010 | Asko 1385 Dishwasher
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
My Asko D1976 dishwasher is not cleaning well, andmy Asko D1796 dishwasher is not cleaning well, and there are food particles and pooled water in the bottom. How do I clean this and/or fix the problem?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
uior24567
Sep 08, 2009 | Asko D1796FI Built-in Dishwasher
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
Jun 13, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Jun 15, 2007 | Bosch 24 in. SGS43C12 Classixx...
Asko D1796FI Built-in Dishwasher Logo
309 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
