Question about GE Dryers
My dryer is making a high pitch sound - GE Dryers
    President:
  • 3,773 Answers
Check back main bearing and front felt with slides tub bearing
Check tension pulley and oil
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 02, 2010
I have a Whirlpoll estate dryer It makes a hi pitch sound How do i fix it
There is a belt that surrounds and drives the drying cylinder, or drum, made of similar material as a fan belt in an automobile, except much thinner material, and it encircles the drum. It surrounds the drum, goes thru a smaller motor/roller set and back around again. There is a spray that's used on auto belts to prevent slippage, called "fan belt lubricant" or similar name. It can be sprayed onto the belt thru holes in the rear panel, or if possible, from UNDER the chassis. It is possible to lift the dryer and tilt it backwards, but applying the spray from the rear is easier in some cases. The belt, or small roller assembly is probably the source of the high pitch sound. The tumbler or cylinder, spins on a single spindle but rarely needs lubricating. These parts are the only moving parts, therefore, the only bits of machinery that might cause the high-pitched sound you hear.
Sep 21, 2014 | Dryers
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
I have a newer model GE dishwasher. About a couple of weeks ago we lost power to home. When power was returned the dishwasher was making a high pitch sound and power was not returned to the front...
Hello
High pitch sound comes when the main control also known as the electronic board goes bad and needs replacement. Please try to blow air with hair dryer on the display just to check if that'll solve the problem. Hope you understand...If it does not then replacement of part is only recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
