Question about Gigabyte GA-G41M-ES2L Motherboard
Dear Friends i have used in gigabyte mother board model no:GA-G41M-ES2L the problem is how i update my bios now is currently used in old version 1.0 but i have to update my bios pls tell me and solve my problem
  • 210 Answers
You need to flash the bios .
download the new bios from gigabyte website and follow their instructions on how to update bios. be very carefull when doing this because if done incorrectly it would render your motherboard useless permanently .
in my experience if your m/b is working its best not to update the bios only time i would update the bios would be if the new bios update has new features that i really needed . if not i would not really flash the bios .
Posted on Aug 02, 2010
Can Gigabyte GA-G41M Motherboard will support pentium d 925 processor
Hi there
Without detailed info about which model of G41 board you have it is impossible to give a definitive answer as looking at the Gigabyte website, some do and some don't. If you go to this page,
http://www.gigabyte.com/search/search.aspx?kw=GA-G41M#pr-1
you will find a list of G41 boards. If you click on your board you will go to a page with several tabs, one of which is "support & downloads". If you click on this you will find a red label saying "CPU support list". If you click on this you will get a long list of the PUs supported by that particular mobo.
Good hunting
Feb 08, 2013 | Gigabyte GA-G41M-ES2L Motherboard
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
I have changed the motherboard from Intel to Gigabyte(GA-G32M ES2L) since then the problem of my pc freezing while playing games started. My configuration is Processor:Pentium D...
1) Make sure that your Power Source is giving enough energy to the new Mother Board and make sure it's compatible.
2) Make sure that the new Mother Board is compatible with all of your current hardware, you can check this in the webpage from the Mother Board Company.
3) Check the voltage requirements for the Mother Board, check the BUS speed of the Mother Board and compatibility with the transfer speed of each of your current hardware.
4) It's never recommended yo change only a Mother Board since usually there's going to be problems with the rest of the hardware if it wasn't changed, if the problem persists, you'll have to buy new hardware that is compatible with your new Mother Board.
5) If you know how a BIOS works and how to configure one, you could also check the configuration in the BIOS, not sure it will work but it's worth a try if you know what you're doing.
May 27, 2011 | Computers & Internet
I have version 1.1 of the G41M-ES2l and the easy energy saver program refuses to install stating flatly: "The motherboard does not support Easy Energy Saver. Installation will abort." I have...
The most probable cause is a change in the Bios chip used or another Architecture change made on the motherboard. There is a small possibility it is a bad motherboard but most likely it is a small change to the coding on one of the chips used or in the EES software you are using.
Feb 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
How can i change intel chip on my gigabite motherboard
Try this . Explains quite a bit. http://www.iusermanual.com/motherboard/gigabyte-ga-g41m-es2l-motherboard-manual.htm
Feb 17, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Installed new motherboard (Gigabyte GA-G41M-ES2L), I cannot figure out where to plug the blue & white wire coming from the main power button on the front of the computer on the motherboard. Please...
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Dec 30, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Gigabyte GA-G41M-ES2L Motherboard Logo
350 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
