Question about LG Heating & Cooling
I installed a fellini mini split modrl 13-05101 after powering up coil fan starts for a minuit then shuts down with lights flashingtimer and operation what bcould be the problem?
4 Suggested Answers
  • 81 Answers
SOURCE: my samsung split type airconditioner is shutting down.
This is an outdoor unit error. I would have the system serviced.
Mat
Posted on Jul 16, 2009
  • 17 Answers
SOURCE: I just installed a ductless mini split 12000. when
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Posted on Oct 28, 2009
SOURCE: e4 in an innovair a/c
Check the Capacitor.
Posted on Oct 06, 2011
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
My 9000 Btu Kenwood Continental Series split unit shuts down compressor after every 10-15 minuits regardles of room temp. Gas pressure is OK & I have tried replacenig cooling sensor but to no use. I am...
Sounds like the compressor may be overheating. You need to check the outdoor condenser coil it may be stopped up with dirt, in turn, overheating the compressor. The condenser coil looks like a radiator and the outdoor fan blows through it, in a sense releasing the hot air from the building. If the coil is stopped up, it can not release the heat. You can wash this coil out with a hose and sprayer. Just be careful not to get the motor wet and be sure to shut off power.
Jun 24, 2011 | Kenwood Heating & Cooling
AmcorAire Duo. Compressor runs, but fan will not. system shuts off after a rew minutes (overheating coils?). Has the fan burned out or is there a relay that needs to be re-set?
There is a solid state fan capacitor for your system, I would change that part first.
We stock a complete line of parts for Amcor Mini Split Systems.
Support@Pridiom.com
201-266-8234 option 2
Sep 07, 2010 | AmcorAire UCHW-H18AF2 Split System Air...
After about ten minuites of playing the amp shuts down and goes to protect mode.. I can then wait 2 minuites and turn it back on and it goes for a while again before repeating the sequence. Is it my...
Amps shut down due to, A: Short circuit, B: Overload. C: Over Heating. It is possible that the Output devices inside the Amp. get too hot during use, Are your speaker "Leads" "Big" enough? Is you Power Positive wire the same, Also as you say, Check your Earth. Sometimes a Fan on the output devices helps.
Mar 10, 2010 | Car Audio & Video
My LG LAN125 mini split heat pump occasionally shuts down in cooling mode while displaying the code CA. The LG tech tells me there is no such code. When this happens, I have to cycle power off and back on...
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Jun 28, 2009 | LG LS-L1210CL Mini Split Air Conditioner
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
230 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
