Question about Cameras
Lense error and i cant fix it and the screen just comes up and says lense error
  • 3,230 Answers
Well lens errors is a very common error on Digital Camera. Usually it's sand or grit interfering with the lens extension mechanism. Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). If further you have the same problem - that means there is a gear-motor alignment of the lens which moves in and out with the help of motor (it need some repair). This part is replaceable at any authorized Service Center.
Hope it helps......Post comments if you need further help or information......
Good Luck!!
Thanks for using FixYa!
Posted on Aug 02, 2010
I am having a problem with my nikon s210...Try to on the camera...the message on the screen is LENSE ERROR. The lense cannot be closed....
This is probably THE most common single failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2010 | Cameras
LCD screen says "lense error" camera will not operate
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 10, 2009 | Casio Exilim EX-Z57 Digital Camera
My coolpix l18's lense will not retract. It says "lense error"
hi there, i am sorry but there is no reset button that can fix this problem. the gears on the lense have been dis lodged and needs to be reposition. the camara would have to be picked down completly for the lense to be removed and this is nothing you can do unless you know what you are doing. once re-posistioned the error code will go away and your camara will work as normal.you will need a technition and i cant do it for you because i am all the way i the caribbean (barbados to be exact) good luck and let me know if you get it repaired please.
Mar 14, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix P4 Lense Error
Yeah that's a pretty catastrophic error. Go to a local photographer, they might be able to help fix.
Aug 17, 2008 | Nikon COOLPIX P4 Digital Camera
Error 61:00
I found this on another website. After trying the bang and blow method....I found that it really does work!!!! I thought I was going to have to buy a new camera. I am SO thankful to have found this. I hope they don't mind me reposting it on this site.
Added by Phillip Ewing on 04/Jan/05 at 04:44:53
We had the same problem, and we fixed it! First, identify that it''s the AF motor drive by A) Turning it on and putting your ears against the camera, then hearing a humming noise for about 5 seconds. B) The error comes up flashing on the screen: "E:61:00". Okay, so you''ve identified your problem! Next you wanna fix it, right? ;) A) Put the camera about a half inch from a hard surface. B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time. If that doesnt fix it, try this: A) Turn it on and let the lense go out fully B) See where the lense comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!) Now turn it off/on again, and it should be fixed! If not, try these steps a few more times. If still nothing, then I suggest phoning Sony, but this DID work for us, so hopefully it''ll work for you :)
Mar 14, 2008 | Cameras
Lense wont open
Firmware fault Tell Olympus Tech Support
May 04, 2007 | Olympus Camedia C-50 Zoom Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Cameras Logo
85 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
