Question about Roper REX4634KQ Electric Dryer
Changed my dryer from a 3 prong to a 4 prong pig tail. I have the red w/ red, white with white, black with black and the green is grounded, but no power. Any idea what my problem is?
    President:
  • 3,773 Answers
Should have 220v between the Red and the Black. White in the middle and the green to the case of the dryer.
But sometimes colors mean nothing because the wall plug may be
wired wrong.
Check breaker and the wall plug for 220v.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 02, 2010
How do you change 3 prong to 4 prong cord?
On a three-prong cord there is a black, a red, and a white wire. The black and red are hot and the white is neutral (return). Return on the dryer is also in these cases the ground which is shunted to the netal case of the dryer. On a four prong, you have black, red, white, and green wires. The black, red, and white are the same as before, but the green is a direct connection to the dryer case for ground. This ensures proper grounding and was first introduced in to mobile home installations, where the electrical system may not always be properly grounded.
Jul 16, 2015 | Whirlpool Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
I have a 4 wired pig tail...dryer has 3 terminals...can I connect the ground wire to the neutral terminal?
Match the red to red, black to black, white to center. Remove the green from the center terminal that connects to the case and terminate it back on the center white terminal. Hook the green from the cord to the cabinet where you removed the green from in previous step. Be sure the black and red wires are on the outside terminals!
Dec 28, 2010 | Dryers
Changing pig tail from three prong to 4 prong on maytag dryer where do i put the red black white and green wires on the pig tail connection on the dryer
the red black and white wire go in the same place as the other wires and the green wire gets screwed to the green ground screw.
the white wire goes in the middle red to the left and black to the right.or just look att he wires and match them
Mar 09, 2010 | Dryers
Dryer is turning but no heat is coming out
If you had a 3 prong originaly you probably have only 3 wires to work with, either a red and black and white or a black and a black with a red stripe and a bare stranded wire. The black and red are ALWAYS the 2 hot wires 230 volt. The white or bare are the neutral / common wires. If you only have 3 you will need to get your equipment ground from a cold water line to the 4th prong.
Another option leave the 3 prong in the wall and install the old 3 prong pig tail on the new dryer then ground the frame of the dryer to the nearest cold water line. The water line must be metalic for this to work.
Dave
Mar 15, 2009 | Whirlpool Dryers
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
I am trying tochange my
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Feb 29, 2008 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
112 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
