Question about Vizio L32 32 in. LCD HDTV
Visio L32, screen went blank . Tryed unplugging and resetting, nothing worked.
  • 19 Answers
See if this works: I called Vizio with my problem and was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in.
Hope this works for you, if it does, let me know by coming back and voting. Thanks!
Posted on Sep 12, 2010
  • 6 more comments
  • easyfixr Sep 18, 2010
    Worked for me.
  • QueenLily Sep 29, 2010
    Did not work for me.
  • crimsonxrush Oct 02, 2010
    not me
  • cw1965 Oct 11, 2010
    worked for me - my set was turning off when I adjusted volume on remote. Reset successful, thanks!
  • sheena221 Oct 17, 2010
    Hello I tried this and it did not work for me and I tried something else that worked so maybe it will help you to......go into your menu it will say picture mode under that you will see backlight if you pic mode is on movie take your backlight down to 18-20 if its on game ajust to 65 if on standard adjust to 27, custom 26. Hope this helps!
  • chancharly Nov 16, 2010
    Thanks. Worked for me. Got my fingers crossed it stays on.
  • oldbaysweaty May 17, 2012
    Worked for me! Amazed that this was the solution to my problem. Many many thanks.
    Worked for me. Amazed that this was the solution to my problem. Many many thanks!
  • Vizio Master
  • 5,568 Answers
If both video and audio are missing, the problem is likely the main power supply. Switched mode power supplies are very efficient but also very fussy about component quality and one of the cheapest components in them, the electrolytic capacitor, has been chosen on cost alone, they tend to break down chemically due to the higher frequencies many of them handle. There are points in the power supply circuit that stresses these caps and if they were not bought for the use to which they are put, they will go bad after a fairly short period of time.
These supplies are often bought assembled and if so, they will be on a separate circuit board.
If you wish to experiment in verifying the source of your problem, you will need some 'freeze spray' used for electronic troubleshooting. This chemical is in smaller pressurized cans costing $5-10 US and can be found at electronic supply stores and I would recommend buying a pair since they are quickly depleted.
You will need to remove the back panel of your set and supply it with AC. Look for a smaller circuit board with larger than average components on it, particularly larger 'cans' and block-like chunks which are chokes and transformers. Keep your fingers clear of any bare parts on this board, they can have painful voltages on them. The larger capacitors (cylindrical cans) are rarely at fault; direct short bursts of freeze spray at the smaller capacitors and wait 10-15 seconds for the spray to 'soak in' before spraying the next. You can identify capacitors by their appearance and markings which will include + and - marks along with values such as '47uF/50VDC.' If you are lucky, when you find the failed cap, the set will turn on temporarily.
Then you can decide if you want to pursue a replacement board or possibly a repair. If you buy a new board, don't discard the original since it is quite possible that the new board will fail eventually too. Smaller companies are offering repair of such boards but since I am no longer in business, I can't recommend myself or anyone else. Post (comment) back to this thread if you require further help.
Good luck-
Posted on Aug 02, 2010
  • 28 Answers
Is the Amber LED near the power putton on? There is a problem with this series that the Microprocessor Reset Supervisory chip goes bad. On the main PCB (With all the RCA jacks). Top left about 3 inches in from the edge, the part is U26 ASM809 (alternate MAX809M)
Have fixed this many times. but as others have said the SMPS Caps need to be checked too.
Posted on Dec 23, 2010
32 IN VIZIO WHEN IT TURNS ON IT GOES ON BLACK SCREEN AND CANT TURN THE CHANNELS UP OR DOWN OR EVEN MENU
Posted on Oct 21, 2010
Black Screen on Vizio E322Ar
Due to the cost of repairing this I would just replace the TV
Oct 12, 2016 | Vizio L32 32 in. LCD HDTV
Sound went out
http://www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2/ Above is your user manual, below is your service manual. Check, your Mute, isn't on? nationalservicealliance.com/visio/VIZIO-L37HDTV.pdf
May 27, 2010 | Vizio L32 32 in. LCD HDTV
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
Sep 22, 2009 | Vizio L32 32 in. LCD HDTV
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
Lcd tipped back and hit the wall, all went black
change the whole unit. if its under warranty, so let it back to where you purchase it.
Jan 03, 2009 | Vizio L32 32 in. LCD HDTV
While traveling in New Hampshire, the screen went blank (green)
It came back on when we crossed the border back into the USA from Canada.
Dec 21, 2008 | GPS
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Hi, I am thinking of buying a used Visio L32 at a really great price.
I have never heard of pressure point lines. This particular model of Visio has a lot of problems wih the lcd panel and the lcd control module. Major problems and major expense. In my opinion a very low quality product and I will never purchase a Visio.
Feb 26, 2008 | Vizio L32 32 in. LCD HDTV
50" Visio goes blank after 10 - 15 minutes, blanks on and off.
I have a 32" Vizio and i have the same problem...... I've had it for five days and I'm not happy about it......... Looks like I'll be taking it back if I can't get help...
Dec 30, 2007 | Vizio L32 32 in. LCD HDTV
Frozen or dead
complain with te company and make them give you a refund!!!
Sep 04, 2007 | Creative Labs ZEN V Plus MP3 Player
Vizio L32 32 in. LCD HDTV Logo
2,028 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
