Question about Microwave Ovens
Need the driver for windows 7 Bluetooth USB Adapter CNBTU1
The KX-TG1061 base phone stopped working after a close lightning strike. The handsets are fine. Can the mother unit be repaired?
<a href="http://www.windowssoftwares.xyz">windowssoftwares</a>
<a href="http://www.whatsappforwindows.xyz">whatsappforwindows</a>
<a href="http://www.newsatoz.xyz">news</a>
<a href="http://www.moviesreviews.xyz">moviesrevies windows</a>
<a href="http://www.recoverdeletedfiles.club">recover deleted files windows</a>
<a href="http://www.downloadandroidapk.club">download android apk windows</a>
<a href="http://www.appsforpc.club">apps for pc windows</a>
<a href="http://www.javacompressor.in">java script compressor</a>
<a href="http://www.clickhunk.com">windows softwares apps</a>
<a href="http://www.bahubaliseries.com">windows softwares </a>
<a href="">windows softwares whatsapp apps</a>
Jun 02, 2016 | Panasonic Kx-tg1061m Expandable Digital...
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
I have a new ranghood with a 150mm duct, how can I connect this to the existing 125mm duct in my kitchen
If this is a circular duct there are 125 to 150 mm adaptors / reducers available at most home DIY stores.
http://www.fastlec.co.uk/circular-spigot-adapter-150mm-to-125mm-duct-reducer-p-1720.html
larger image:
http://www.fastlec.co.uk/images/ventilation/domus/118.jpg
This should be what you need. It would be a matter of finding your local source for the reducer / adapter.
Thanks for choosing FixYa,
Kelly
Aug 05, 2011 | Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
I need software for sch-f339 dc16 compatable to windows 7
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Feb 09, 2011 | Microwave Ovens
Kenmore elite microwave displays F9 after a few seconds
I have the same problem. The sears guy told me that I needed a phillips screw driver and a torx adapter/driver to remove the entire microwave cover ( it slides off0 to gain acess to remove and replace the bulb.
Dec 29, 2008 | Kenmore 63792 Microwave Oven
Bought nikkai 12v microwave.but says in manual under features " powered by dc12 or 24v direct to battery or cigarette socket" Can i plug into 24v socket?
Sounds like it but I would double-check the manual to be sure.
Also check to see if the manual lists Accessories, such as a 24V adapter. That would probably mean you need a special adapter.
Aug 29, 2008 | Microwave Ovens
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Microwave Ovens Logo
227 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
