Question about GE Profile Harmony DPGT750EC Electric Dryer
I have a 5 yr old GE Harmony Dryer and it sometimes does not turn the drum. I'd say about 2/3's of the time it operates totally normally, but the other times the drum doesn't turn and you have to open the door and spin the drum a bit and then it usually works. It also recently stopped blowing so I just replaced the blower motor which fixed that problem. In the process of replacing that, I inspected the belt and even had a local appliance guy inspect the belt and it seems fine. I've heard there is some sort of switch that tells the motor to turn the drum...maybe that's the problem?
    Scholar:
  • 32 Answers
Unfortunately your motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are GE certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on doing it yourself, if you'd like.
The switch your talking about is a centrifugal switch inside the motor. Once the motor turns to a specific RPM, it makes and keeps the motor going until the timer turns it off or the door is opened. But it is the motor itself which starts the spinning. But the motor is not doing it's job so the C switch doesn't come into play.
Best, G
Posted on Aug 03, 2010
My Ge Harmony Dryer sometimes will not spend. It heats up but will not spend at times.
Try manually start the dryer. Take a piece of tape and tape the switch on the door. Then take one hand turn the drum and press the start button at the same time. If is starts then then you have bad motor.
May 18, 2011 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
May 14, 2010 | GE Profile Harmony DPGT750EC Electric...
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony dryer drum does not turn
open the top, pry up be careful not to chip your finish. It is hinged in the rear.
Is thr a wear spot around the drum?
It probably is belt drive
Jan 27, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
59 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
