Question about John Deere Garden
JD 14SB won't stay running unless you spry gas into carb
  • 100 Answers
Could be number of things....low compression....valve clearance...blocked jets in carby...air leaks...
Posted on Aug 14, 2010
How do you replace the clutch on John Deere 14sb walk-behind?
google your question. all sorts of help popps up
Jul 15, 2014 | Garden
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
My b&s 6.5hp log splitter wont stay running unless i spray gas directly into the carb... this is where it's get funny, i took a carb off my
If your gas is E-10 then there is a strong possibility that the line from the tank is blocked, also could be a filter and even sludge in the gas tank all caused by E-10 seperating and becoming thick.
Sep 11, 2012 | Briggs & Stratton Briggs Stratton...
My benz won't stay running unless I hold the gas down constantly
sounds like a fuel pressure issue check fuel filter lines& linkage
Sep 04, 2012 | 1992 Mercedes-Benz Mercedes Benz 300 Class
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
I have a 1984 ez-go gas golf cart it won't run unless you take the gas line off and squrit gas direct into the carburator throat what is the problem
remove your carb. and thouroughly clean it, remove diaphrams/needle and give it a good clean and rebuilt job.
Feb 14, 2012 | Cars & Trucks
Toro recycler mower won't stay running
take apart the carb float and clean it out, then take apart the rest of the carb and spray cleaner through it. sounds like you might have some old gas turned to jelly in your carb thats plugging it too much for the typical pressures inside the carb to **** through
Jan 25, 2012 | Toro Power Lawn Mower
Engine won't run unless the choke is on - Deere 14SB Push Mower
It's starving for fuel. When you push the throttle all the way forward it closes the choke. You took it apart but you probably didn;t get all the junk out of it. Easy fix is to put some SeaFoam into the tank and run it. This cleans all deposits and debris from the jets. I have used this stuff and put it in the tank and start the engine and sit back and let it run. After about 5 minutes the engine will smooth out and run fine.
Jul 30, 2009 | Garden
14sb mower starts and runs 2-4 min, then quits
The plug is breaking down.Change the plug.
Jul 24, 2009 | Garden
Garden Logo
488 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
