Question about Sangean DT300VW AM/FM/Weather/TV Radio
Nothing works. Just flashes 12:00 - Sangean DT300VW AM/FM/Weather/TV Radio
Quite likely it is a problem with the power-on button. You need to open the case. Lie radio face down and insert a screwdriver in the slot at center bottom and twist slowly till you hear popping noises. Then work your way slowly around the opening seam on both sides of the case. Press in with the screwdriver as you do this. The case top will become detached from the bottom. Lift up and open it pivoting around where the volume control and lock switch are. The blue on/off button will fall out. You should blow out any dust with a computer air-spray can. Probably you need to put a dab of epoxy onto the small raised blue platform on the on-off button that sits immediately above the black switch on the circuit board. Let it harden before re-assembling the unit. This worked for me.
Posted on Aug 09, 2010
What are the best aviation subjects to start an aviation website with?
Really depends who you think your audience is. Lay people may just want to know how a plane flys or why certain things happen on commercial flights. Pilots may want to learn about skills/ratings they havent acquired yet, recent incidents.
May 20, 2017 | Aircrafts
How many btus per sq ft?
12,00 per 400 sq.ft.
Sep 12, 2015 | Heating & Cooling
Mitsubishi dion.the vehicle can't start
is many things which can result in not starting.
1) check if ur starter motor cranks if it does ,check for spark.
2)if the starter doesnt check your battery state by using a multimeter take the readings if is 12,00 volts or more is good
3)check your battery terminals contacts against the battery poles if bad use hot water pour over them but extra careful is needed because some of electronic component hates water
Dec 01, 2013 | Cars & Trucks
Can you translate the model number please
I cant tell you the date it was made, only from the serial number. But the 036 tells me it is a 3 ton unit. There is 12,00 btu per ton of cooling, so on your carrier, 3x12=36, which will be the 036. That's about all I can give you on the number.
Shastalaker7
Nov 21, 2011 | Carrier 38CKC036 Air Conditioner
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Oct 22, 2010 | Broderbund PrintMaster Platinum
How do i reconnect capacitor cbb65a-1 from my haier esa3125 12,00
The wires usually just have connectors that push on/pull off. Some capacitors run the fan and the compressor and have 3 different terminals. It is very important to make sure the wires get put back on the right terminals on this type. You can find a capacitor at a local heating and air store.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
Maytag air conditoner
Unless you can see if the fan is hitting something, you can't. You will need to take it to a repair shop. Sorry.
Jun 09, 2008 | Heating & Cooling
Flash
The flash circuit has gone out the squilling noise is the flash compasitor popped and the acid inside is burning.
Feb 14, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Sangean DT300VW AM/FM/Weather/TV Radio Logo
386 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
