Question about Kenmore 43142 Front Load Washer
Kenmore Model-417.29042991- Light will come on but door will not lock and water will not start to fill tub. Replaced door-latch assembly approx. 18 months ago.
jsrock516
  • 5911 Answers
SOURCE: kenmore washer...the water just runs it never fills up.
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
SOURCE: my Kenmore washing machine he3
I had the problem of my HE3 washer would not drain all the way. Well I am pretty good at fixing stuff so I took apart the botton panel and there was the drain. I opened up the drain plug with a small bucket (gallon size) underneath and it started to drain and drain. Well about 3 gallons and five big beach towels on the floor i thought I fixed it. I found a service award badge and a couple of small socks. So I put everything back together and started to run a cycle. After the cycle finished my daughter decided to open the door and realized it was full again. After we got out the shop vac and sveral more beach towels. I go back to the drain plug and started to noticed the the drain area is clear. So I thought it was a fluke. Unpluged the washer for a few minutes and started another cycle. Once I realized the washer did not drain again, I was starting to get mad. I took the bottom panel off again and looked under the drum and realized I might new a new pump. Well I called my dad to run the issuse by him to see what he thought. About that time my son opened the washer no realizing I was working on it. I am really mad now. My dad stops by and helps clean up the water. He looks at the drum and realizes the rubber drain piece that comes off the drum twists when it is on the drain mode. So I pull the spring clamp off and put a stainless steel hose clamp (.89 cents) and lined up the black rubber drain piece the way it is suppose to on. It has been working great every since. Sometimes you need about 6 gallons of water to realize that it is always the simplest thing that stump you.
Posted on May 04, 2009
mgprice
  • 744 Answers
SOURCE: water doesn't stop filling tub and tub overflows
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Posted on Aug 31, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore 80 series washer valve is leaking and the
Replace the water mixing valve assembly.he part where the hoses attach.
Eric
Posted on Sep 18, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Kenmore 417 washing machine lock won't engage so it won't start.
the door latch is a normal electrical switch,
open the cover, and brridge it and try, maybe it needs adjustment or you didn't fix the wires plug
Oct 21, 2014 | Kenmore Washing Machines
My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
Hello & Welcome to FixYa
This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Kenmore Dishwashers
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore model 110.42832.201 won't start, door won't lock - cycle selection button just flashes.
Hi, check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Take care
Jul 19, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Why won't door latch lock?
The lock is activated by the control board / timer at specific times to prevent opening of the door (like when the tub is filled with water during the wash cycle and during the high speed spin cycle). The electrical or mechanical part of the lock may have failed or the portion of the control board that energizes the lock may have failed.
If it is just the lock, it may be a relatively easy fix - but it is always possible that the failure of the lock also caused the subsequent failure of the control board too (that's just Murphy's Law) . A control board replacement in these machines typically is not overly difficult job; but you may find the board itself may be a fairly expensive part.
I hope this helps
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Maytag Neptune Door Locked
Hello , I can help , this unit will not work without locking the door , the wax motor in the latch assembly has failed , I have replaced a lot of these , usually it is best to replace the entire latch assembly , this is what your plastic lock string connects to. you can try to replace just the wax motor first due to cost difference. you can find it in the latch assembly it is commonly maroon in color and 1 inch rectangular. please ask any other questions you may have and tell me how this works out.
Phil
Jan 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 43142 Front Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
