Question about JVC GR-D31EK Mini DV Digital Camcorder
Camera will not starat - message is condensation, operation paused. Cannot play or record
THE SCREEN DISPLAY THE FOLLOWING MESSAGE: CONDENSATION, OPERATION PAUSED. AND I CAN'T DO ANYTHING (PLAY, RECORD, ETC)
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 31, 2010 | JVC GR-DX77AG Camcorder
Condensation operation paused
Remove power from the camera. I remove the battery as well. In the back of where the tapes go, on the left side is a silver component. It's just behind a metal roller that hangs down from a plastic piece over the head. If you look behind the roller diagonally across where the tape goes, you can see a black square on the right side of the silver component. Clean this (gently!) with a moist cotton swab. The swap should get a bit of black gunk off. I'd recommend cleaning it with a dry swab next to remove any moisture. Wait a minute or so to be sure it's dry. Then re-apply power. You should not see a false condensation message for a long time.
Mar 13, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Condensation, operation paused
Try running a cleaning tape through the JVC 2 or 3 times and also wiping all around the tape compartment with a long cotton bud soaked with isopropyl alcohol. It cured my problem in Singapore.
Oct 30, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
Please Wait Condensation, Operation Paused
This is often referred to as DEW and is a sensor inside the camera that detects moisture. You can hasten the removal most times by warming the camera with a hairdryer on medium setting and not too close to the plastic case. When you store the camera store it with a few of those little bags of silicone crystals that come in many packages that we just throw away.
Please rate our help to keep the service online
Aug 21, 2009 | JVC Video Cameras
CONDENSATION
Condensation message comes when video head drum got moisture and such moisture can damage tape and video heads. So camera stops function of tape loading and play/ rew/ ff.
Eject and take out tape, if any in camera and blow hot air by hair dryer for 1-2 minutes from at least 6"distance in tape mechanism.
This will evaporate any moisture on video head drum.
and if camera still gives error then dew sensor in camera is bad and you need tech person to replace it.
Dec 16, 2008 | JVC GR-D33US Camcorder
Jvc comcorder getting error message "condensation, operation paused"
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
May 18, 2008 | JVC 580136 Camcorder
Condensation, operation paused, JVC Video Camera model GR-D70AS
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Condensation operation posed
Mar 02, 2008 | JVC GR-D30U Camcorder
How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
Dec 26, 2007 | Jazz DV-179 Digital Camera
JVC GR-D31EK Mini DV Digital Camcorder Logo
59 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
