Question about Cameras
Canon 450D Brand new, just got it out of the box and I keep getting Err 99 when I try to shoot. Haven't managed to take any photos yet. I tried 2 different memory cards, cleaned the small gold connector bits in the lens and the camera, took the battery out etc, nothing seems to work
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
Its a common Error on these kind of cameras, I have never heard of someone who had it so fast. You can try do some adjustments but your best way to fix it is to send it back to Canon, since its brand new.
Here are some thread with information about the err 99:
http://www.fixya.com/support/t472280-error_99
http://forums.dpreview.com/forums/read.asp?forum=1019&message=27453471
Good luck
Posted on Apr 30, 2008
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
LCD Screen shows Err 99. No shooting is possible
Err 99 could mean several different things, such as... Memory Card
Lens
Lens contacts....
A few things you can try.
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad.
Try another lens if you can
Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens)
I have heard Canon recommend upgrading the camera's firmware (go to Canon's website to download the latest firmware and follow Canon's instructions for the upgrade).
I saved the worst for last, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Good Luck
May 05, 2011 | Canon Digital Rebel XSi Digital Camera
Err 99 shooting is not possible i have changed the battery pack installed a new lens also removed the cf card but still the err is coming wot should i do
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Feb 26, 2011 | Canon Rebel XTi / EOS 400D (body only)...
No display nor will it shoot
SHUTTER IS FAULTY YOU NEED TO REPLACE NEW ONE
Jul 11, 2010 | Canon EOS 450D Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
Mar 29, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Cameras Logo
547 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
