Question about Buffalo Technology (USA), INC. - 500GB DRIVESTATION EXTERNAL USB 500 GB Hard Drive
I dropped it and now it makes clicking noises and won't access my files on it. Have I damaged it beyond repair. It also won't show in the USB drivers as actively reading. What do I do? I am using OS Vista Home Premium.
    President:
  • 2,600 Answers
Unfortunately, dropping the hard drive, especially when it is powered on will damage the hard drive beyond repair for the typicl mlay person. What happens is when the drive is powered on, the read/write heads will idle in the middle of the platters, if these very fragile heads come into contact with the platters they will be destroyed, most likely that happened when the drive fell and impacted. It does not take much to destrot these drives. Newer drives have a program that detects "G" or gravity effects and the read/write heads snap into a protective cover to protect themselves. There is no repair that I can think of that the typical repair shop can perform, if the data just has to be recoevered, the drive will need to be disassembled in a "clean" roomand the data recovered from a special platter reader.
Posted on Aug 02, 2010
Testimonial: "Thanks for the reply. I had already thought so but hoped for another solution. Thank you so much for the feed back."
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
Verbatim 1 tb frozen
the screeching noise worries me a bit
its sounds the video file being transfered was a bit to much for the usb capacity
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
even if you dont have any red or yellow marks you might have to
Click Start, then type device manager in the Search box then click Device Manager
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete restart your computer. Your USB controllers will automatically install
This method prevents your USB external drive from powering down
Disable USB selective suspend setting.
This method prevents your USB external drive from powering down.
Click the Start button type power plan in the Search box then click Choose a power plan.
Next to your currently selected plan click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings then expand USB selective suspend settings.
Click Plugged in then click the drop down menu and select disabled.
If youre using a laptop click Battery then click the drop down menu and select disabled.
Click Apply then click OK.
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 28, 2012 | Computers & Internet
I have an external Seagate HD Barracuda 7200.10 300GB drive. We have all of our family pictures loaded in this drive. our dog accidentally dropped the drive and now we can not access the drive, all I...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 28, 2011 | Computers & Internet
Hi:I have a Beyond Micro, model HD 337 U2C. Suddenly after no problems I can't access about 3/4 of the content of the hard drive. It sounds OK , but just is not functioning. If you can't fix the...
if you can access your beyond micro hard drive
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Feb 05, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I managed to drop the unit about 18 inches of the table and now it just makes a spinning noise then nothing
It sounds like the drive is damaged beyond repair. You could try for a warranty replacement from the vendor. If there is important data on the drive you would like to recover, it will likely cost a lot to retrieve it.
Oct 26, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Physical damage on the memorex travel drive - the disk is making a noise when it is plugged in but it is unable to show any files on the computer
it can be fixed if the hard drive is not damaged. If its damaged, you will have to get another one.
I don't stay in Perth, so I would not know where to find a repairer in Perth.
Maybe you should look around, you might find someone who can repair in Perth.
Take care.
Jan 11, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
I dropped my external hard drive - a Verbetim terrabyte hard drive. Now, when I turn it on, it makes mechanical noises and won't connect to my computer (USB). I'm not too concerned about trying to fix the...
If your drive is making whining and clicking sounds, then you have a mechanically damaged drive which had what we called a 'head crash' due to the drop!
If you can read/access the disk partitions/drives, I strongly suggest that you perform a full disk backup (with track error skipping) to another device. Also try a file by file copy to another drive (slow but you know exactly what is accessible).
You may want to try to use 'Spinrite' (Google and read about it first) to attempt to repair some of the issues but unfortunately, a disk 'head crash' is usually fatal physical condition and data recovery requires specialized equipment and is VERY expensive!
Hope it helps: let me know ho you go!
Dec 29, 2009 | Verbatim External, USB 2.0, 750GB...
I dropped a my book external hard drive
The hard drive could be damaged but the USB adapter case electronics is OK. Therefore the computer can see the USB device (adapter case) but not the hard drive. If the hard drive makes a clicking noise or you cannot hear the hard drive spin, then the hard drive is definitely faulty.
Oct 22, 2009 | Computers & Internet
Arogsy 500GB HD Drive won't boot up
If you have dropped it, most likely the hard disk is damaged, especially if it makes clicking noises..
The case is probably screwed together, but the screws are hidden with plastic covers or under a label.
If you are able to remove the hard drive you can connect the hard drive to an USB hard drive adapter and conect it to a working computer's USB port. It will see it as an external hard drive, if the hard drive is OK you can view and open the folders and files.
You can also connect the hard drive to a desktop PC as a slave drive if the PC's BIOS can support a hard drive of 500Gb.
If you are desparate to recover data from a damaged hard drive, there are companies that can recover data from these drives BUT it will cost you an arm and a leg for their services.
Sep 09, 2009 | Western Digital 500GB My Book World...
Wont Focus
If its making a noise when you try to zoom in and out I would suspect physical damage. The more you mess with it the greater the chances of damaging it beyond economic repair. I would take it to the local authorized canon repair shop.
Jul 26, 2006 | Canon PowerShot S1 IS Digital Camera
Buffalo Technology (USA), INC. - 500GB DRIVESTATION EXTERNAL USB 500 GB Hard Drive Logo
236 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
