Question about ASUS P4P800-X Pentium Motherboard
Adding ide drive to a sata boot p4p800x xp Problem - ASUS P4P800-X Pentium Motherboard the system would not find ANY boot device
  • 1 more comment
  • GaRoMo Apr 25, 2008
    yes, and in that case the system shows boot1=IDE boot2=CDROM
  • ASUS vs IDE Nov 18, 2008
    My research on the internet shows that a wide range of ASUS boards choke on IDE drives (both hard disk and cd/dvd). They seem to especially have trouble booting from them.
    I just bought a P5QL. I get a blue screen when booting from my IDE HD (which boots my older computer just fine). If my new IDE DVD and the HD are both attached, then it won't boot from either (dvd give me "replace system disc" error). If just the DVD is connected, it will sometimes boot from it (not much help without the HD though).
    This appears to be a general ASUS problem and I don't see why they don't offer a solution.
  • Gene Wells May 11, 2010
    So you're saying that you have a PC that currently boots fine from an sata drive, but when you add an ide drive to the system stops booting from the original sata? Please be more specific.
    Thanks,
    Geno
    President:
  • 2,351 Answers
GaRoMo, 2 things. One change the pin on the IDE to a slave. Two open your bios. Asus board press the delete key every two sceonds untill the bios main menu opends. Go to BOOT section & make sure you have the SATA drive to boot. Your IDE should not be listed. Thats it.
Mike
Posted on Apr 25, 2008
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Boot on sata
I found the user manual here :
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
Your problem could be in the bios. Press the delete key repeatedly while booting up to enter the Bios Setup Utility and check these options :
IDE Configuration - as shown in the manual at chapter 4 page 14
Onboard PCI IDE Operate Mode - Enhanced Mode
Enhanced Mode Support On - S-ATA
Configure S-ATA as RAID - no
and also
Boot device priority - as shown in the manual at chapter 4 page 33
set your Sata drive as the 1st boot device
For additional info, refer to the manual in the link above.
Did this solve your problem?
Dec 27, 2012 | ASUS P4P800 SE/865PE/SATA/R/A/GBE/1394...
My motherboard have a prablem meens chipset intel very hot and no eny pictuer in monitor
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
Now restart the PC and see what you get.
Jan 20, 2012 | ASUS P4P800-X Pentium Motherboard
Hello, my main board is asus p4p800-vm running xp home with sp3 upgrade with ide hdd's and is running well. i bought 2 new sata hdd's because the board has 2 sata ports, i set the bios to auto to see the...
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
Jan 06, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Login
You Mean You Want to be prompted on which drive you want to boot, you need a bootloader to do that (there is a way to do it with start>run>msconfig, but its been a while since ive done it, and i dont want to try to explain it, and just confuse you.
Aug 12, 2006 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800-X Pentium Motherboard Logo
607 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
