Question about First Alert 24 Hour Timers - 2 For The Price Of 1
On the top of the 220 first alert timer there are two buttons, timer on and outlet on. Which one should be on if I want to plug timer in an outlet and then plug a light into the timer?
  • 843 Answers
If you want the timer to control the light - TIMER ON If you want the light to be on, regardless of the timer - OUTLET ON
Posted on Aug 02, 2010
When i plug it in there is no display is it broken ?
Reset timer using reset button, and see if functionality begins.
Plug timers into different outlets.
Test outlets for correct polarity and that they deliver at least 80% rated value, 115 volts x 80% = 92 volts.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Most timers have 1 year limited warranty through manufacturer.
Timex timers are not made by or display on Timex website.
Unknown where warranty is honored.
Suggest GE, Woods, Intermatic timers since these have specific web links for warranty coverage, but you have to send timer in.
This is why I suggest buying timers at local box store, then if problem occurs, buy another timer and return defect in new package, thus giving convenient extended warranty coverage.
Nov 23, 2012 | Day-Timer Mwave Tx12626x Timex Electronic...
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
Oct 24, 2012 | First Alert Hardware & Accessories
Instruction manual for First Alert model 220
First Alert timer:
Copy following link for general instructions:
http://waterheatertimer.org/How-to-set-timers.html
Jun 02, 2012 | Hardware & Accessories
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
I bought two First Alert 24 hour timer with clock units some time in the past, but never opened them for use. Now I have opened one of them and the inner pieces are all scattered inside of the unit. The...
First Alert timers have prefix numbers and look similar to Woods promotional timers.
Searching First Alert site turns up no timers, which makes me think they have a timer packaged for them. Why they select promotional timers probably reflects need for retail price point. Searching for your model number turns up no on-line sellers, but does turn up fixya problems about First Alert timers ... which may be why you're here on promise of manuals and repairs.
http://www.firstalert.com/
Woods makes a top-line 2-pack 24-hour timer that sells on Amazon:
These timers have 2-prong outlet, and they will NOT fall apart.
Amazon sells single-pack timers with 3-prong outlet: for 24-hour and 7-day
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
That being said, I've tested these timers.
Except for some brands of box-type timers, timers today are one-piece apparatus that have no repair parts. Bust it and throw it away.
Plug-in wall timers are not supposed to fall apart, or even come apart.
It sounds like first timer out of package is defective.
Sorry for the loss, and frankly I am going to contact First Alert and ask why they don't support their timer customers with manuals and information.
Nov 29, 2010 | First Alert 24 Hour Timers - 2 For The...
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
I have a Tork 806A timer, but no instructions on how to set the on/off cycles.
Tork 806A: There are 6 outlets. Bottom two outlets are always on. Top four outlets controlled by timer all four outlets turn on and off at same time.
Load: Total load on all 6 plugs cannot exceed 1500 Watts, which is typical for 15A circuits. Indoor wall plugs are 15A. Don't add more load to timer than you would put on ordinary wall plug.
Set Time: Rotate dial clockwise to set time. On face of dial, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} push tabs down to turn on loads, pull them up to turn off loads.
Reset: Timer has reset button in top left corner.
Jul 25, 2010 | TORK Digital Interval Timer Ssa100r-24
Need instructions to set the First Alert TM220 Timer.
For the Model TM-220, 24 hour timer set as follows:
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1 hour.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Mar 19, 2010 | First Alert 24 Hour Timers - 2 For The...
First alert timer 220
First Alert 6262 Patterson Pass Road, Suite C Livermore, CA. 94550 1.800.458.1385 orders@vwimc.com
  1. Set current time with arrow at top of dial
  2. Time on, push and slide white pin
  3. Time off, push and slide grey pin
  4. Automatic override, use red switch on side
Comments on some sites that refer to this unit is dont waste your time .. heap of junk, wasted hours and it still didnt work.
So good luck
Please rate our help to keep the FREE service online
Aug 30, 2009 | First Alert 24 Hour Timers - 2 For The...
First Alert 24 Hour Timers - 2 For The Price Of 1 Logo
150 people viewed this question
Top First Alert Hardware & Accessories Experts
Gene Haynes
Tom Chichester
 Mikey
Mikey
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
