Question about Danby DKC645BLS Compact Beverage Cooler
LE on display of Danby Kegerator. Doesn't show
LE on display of Danby Kegerator. Doesn't show temperature and cooling is not working.
  • 4 Answers
SOURCE: danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Posted on Aug 07, 2009
  • 619 Answers
SOURCE: new danby kegerator - tastes like rubber hose
you may report the problem of taste of beer the store where bought it , byu the when it new smell strange but it better clean in second time by flushing of water before you attache the beer tank, for the time the fume of rubber connection still inside on that machine , (in purified water need to back wash in order to make a purified water good taste and clean, ) the term use of that machine is "flushing " .
Posted on Jan 01, 2008
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
SOURCE: kegerator is on but not cold- dkc586bl
1 foot from the wall , unplug for 15 mins and plug back. satisfied , vote for me
Posted on Sep 16, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Danby DWC512BL has stopped cooling. The
moz-screenshot-22.pngmoz-screenshot-26.pngReplace that fan
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 06, 2009
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
I have a Danby Kegerator I purchased at Sams Club a couple years ago. The temperature readout said LE at one point and now it will cool down when I first plug it in, but then it warms up to between 50-70...
contact mark pasieka for a repair.... mail in the board and he can fix it and send it back.... if you live in the chicagoland area he is a liscensed for all types of refridgeration, and since he has 2 degrees in electrical engineering he is especially proficient when the issue is electrical in nature...
mark.pasieka@gmail.com
Sep 21, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
How to make the kegerator colder
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Feb 05, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Temperatuer gauge says LE
If your gauge displays LE, it is below 15 degrees F. That means your beer will freeze. The same problem occured on mine. I called Danby and the rep was very helpful. She informed me it was definately a problem with the temperature pad on the front of kegerator. The part cost less than $3 and shipping was $7. It was an instant fix and it was easy to replace. Remove the four screws to the tower on top, the three screws to the rear, and pull the top off. Flip it over and remove the two screws to the computer. Unplug the old and replace with the new. Very simple job. Due to the low price of the pad, I would order two. The shipping price is the same and I don't have to worry about another keg being ruined because I now have a spare on hand. Hope this helps.
Jul 24, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC645BLS Compact Beverage Cooler Logo
542 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
