Question about Cameras
Over heats and drains battery - Cameras
  • 906 Answers
Kindly advise what type, brand or model of camera you have, so we can further assist you.
Thank you.
Posted on Aug 02, 2010
The street is completely blank on our white and rogers thermostat
Replace the batteries. If no batteries check the drain line for a piece with 2 wires. (Float switch) drain is likely clogged do not leave float out. Must unclog drain
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 23, 2017 | Heating & Cooling
Battery draining fast
If the battery was in the phone then you NEED to replace it.
Jun 28, 2015 | Samsung Mobile Phone Galaxy Duo S S6102...
Bike battery drains fast, bike seat & area below seat gets too hot to sit on
It sounds as though the seat pan might be coming into contact with the battery and thus causing the seat to heat up and drain the battery all at once. My question would be if the battery was recently replaced and an incorrect sized battery was used. If battery isn't under the seat pan itself, check for wires that might have insulation damage that could cause a short and draining the battery. Also some people have installed heated grips on their bikes, maybe the switch for that isn't off when not in use and causing a drain.
Apr 22, 2013 | 2003 Yamaha V Star Classic
Heated seat drains battery when key is out
I would look for a relay problem first. The switch should ground a relay and that relay may be sticking.
If your owners manual does not state where the relay is let me know.
Sep 28, 2012 | 2002 Pontiac Grand Prix
My n81 over heats when i am use it for more than 10 minutes and causes the battery to drain and eventually turns off after that
This is a fault in the motherboard, a possible shorting in a semiconductor thereby draining high current and so the battery is drained.
In most cases the motherboard needs a replacement unless the component that is heating is discrete, a possible diode or regulator.
Need to take consensus after a visual check to estimate.
Oct 03, 2011 | Nokia N81
Can i charge this battery with a normal auto battery charger?
Unless the battery is fully drained the car battery charger is good enough to charge the battery mentioned. The car battery charger has got about 3-5 amps of capacity and the only possible problem will be the time taken to build up if the charge is fully down... might heat up a bit but is normal.
Only if the above battery is bad/shorted will it result in draining more current resulting in heating of the charger.
Nov 25, 2010 | Hi-Capacity LC-R127R2CH1 Panasonic 12 volt...
Heats up drains battery fast
heats up?do you mean the unit itself heats up fast?if that so.you unit has a short circuit inside on it thats why your battery drains so fast...,but if its not,the problem is on your battery.Not even a battery can charge is meaning that your battery is still good.If a battery has defect or let me say it is already weak,it will not already stored a longer life of a power.,becoz if that so,the current or well known as the ampere is already goes down than the given specification when it is new..and thats the reason why it is already fast draining.
Oct 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Power Drain out early
Please check you battery, it might have a problem if it gets heated . This can damage your ears . Please change to a new battery to protect your phone and health.
Jan 29, 2009 | Nokia N72 Cellular Phone
My NOKIA 5310 is heating up + battery drains in 3 hours,
it realy soun sounds like liquid damage, take it in for repairs, if you wnat to try youreself open the phone wash it with metholated sprirts and see you should be able to see the damage white powder like
Dec 07, 2008 | Nokia 5310 Cellular Phone
Cameras Logo
81 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
