Question about Elna 2007 Mechanical Sewing Machine
Elna sewing machine, the timing is out.
I've got an Elna series sewing machine, and the timing has gone out, the needle is hitting the bottom bobbin case too soon so is'nt sewing, I think that the timing has gone out on the motor, I've taken the covers of the machine and cleaned it up myself but don't know how to do this myself and am trying to avoid expensive repair bills! Thanks,
Katie Dadds
  • 5 more comments
  • anne b May 02, 2008
    the timing has gone out on my singer home sewing machine
  • Anonymous May 11, 2008
    I am sewing on a janome memory craft 3000. My problem is that the machine is randomly skipping stitches. this has happened once before, and the timing was out... I simply can not afford the repairs, but I am pretty good at fixing things. can you help? please
    I have changed the needle
    re-threaded top and bobbin
  • Christine D Jun 18, 2008
    Have an older elna elnita 130. needle just barely nips the boobin
    case when I sew. I haven't tries to fix it as I didn't know where to start.
  • Anonymous Aug 06, 2008
    my machine is not making a stich, has been cleaned and is running vey nice but no connecting stiches at all.
  • renwortiz Aug 06, 2008
    I have a kenmore machine, I love it, it has done a great job over the years. I keep it in good shape and oil it up often. It sounds like it is sewing, it looks like it is sewing, but no connections are being made from either of the strings... No stiches are being made, help!!
  • alyallwi Sep 01, 2008
    manual for elna 6001 sewing machine wanted
  • Anonymous Mar 27, 2014
    My needle is hitting the bobbin housing and breaking because it's not hitting in the hole for the hook.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
I have an Elna 7000. The needle has started to hit the bottom of the bobbin case. Is there a way that I can fix this?
Install a brand new needle. If that doesn't fix the problem, you need to take it for service.
May 07, 2018 | Elna Sewing Machines
I was sewing with elna machine and ran out of thread. This caused the thread to ball up underneath and "jam" the machine. I cleared it out and rethreaded it, but now the top thread doesn't catch the bobbin...
it is possible that the sewing machine has a timing problem, but check to see if the needle is inserted correctly into the needle holder
make sure the bobbin is inserted correctly into the bobbin case if the machine has a top loading bobbin
if the machine has a side or front loading bobbin also make sure the bobbin case is inserted correctly into the machine.
and also make sure the top thread has not come off the thread take up lever
Aug 20, 2013 | Brother XR-65t Mechanical Sewing Machine
My elna 7000 bobbin thread will not pull up with the needle in order to sew.
try changing the needle
rethread the machine top and bobbin
here is a link for a manual if you don't have one
http://sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/7000_Instruction_Manual.htm
try a different bobbin incase that one is warped
it's also possible that the machine could need the timing checked
Nov 20, 2012 | Elna Quilter's Dream 6003Q
The thread on the needle of my Elna sewing machine wont pick up the thread on the bobbin and bring it up?
Is your needle in backwards, always the flat shank to the back, make sure it is in all the way up in its housing too. Is it a new needle, not blunt, bent or hooked on the tip, sometimes we don't notice butthe needle is very important and should be changed every 4-6 hours sewing time. The shuttle hook goes around and catches the upper thread during stitch-formation, timing of these two parts is crucial so if this is a machine that has been damaged or do you suspect the timing is out perhaps. If so, technician time.
Aug 22, 2012 | Elna Sewing Machines
if changing the needle doesn't help then it's possible that the machine
is out of time & needs to be checked at a repair shop
Janome Gem 760 sewing machine: needle hits bobbin casing
from what I've read that you've put down it sounds like the machine is out of time, which means it needs to be fixed at a sewing machine repair shop
Feb 08, 2012 | Sewing Machines
I have a Elna 6003. Recently I started having problems with the stitches skipping, and the machine was making a clicking sound. Now I have discovered that the needle is hitting inside the bobbin case and I...
skipping stitches can be the needle is damaged--flat side of needle goes to the back side of machine
normally when the needle is hitting the inside of the bobbin the timing is usually off, & can only be fixed by a sewing machine repair tech
Jan 31, 2012 | Elna Quilter's Dream 6003Q
Needle hits the white plastic where the bobbin case sits.
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
May 05, 2010 | Elna 7200 Computerized Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
1,472 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
