Question about Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range
SMEG A42 fan motor problem
I have following oven specifications:
SMEG SPA 42016
MOD:A42
n.15108488
gb: 112H3T or F
when switching on the oven the motor works but the fan motor keeps rotating and then moving towards the back of the wall. It looks like as if a part is missing which keeps the fan motor attached. When it moves backwards it makes a loud noise as if metal parts are rubbing against each other. Do I need to buy a new fan motor or just a part missing? Thanks.
  • 106 Answers
Check that the fan mounting screws or bolts are in place and tightened
Posted on Aug 02, 2010
Which of the five small buttons do I press to make the oven function? start
Ok! Until the clock is set the oven will not work, I will describe the 5 buttons as numbers from the left!
Press and hold the 3rd button for 2seconds, then press the 4th or 5th buttons to set the clock to the correct time, then press the 3rd button to set!
Jan 01, 2015 | Smeg Ovens
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Smeg cooker SPA 42016 oven will not heat up although the fan is working and the oven light is on
This happened with my 42016 single oven. It was the element. They can be bought online and are easy to fit.
Mar 17, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a smeg A42-5 oven and the digital clock as gone blank and i'm unable to use the oven but the grill still works. can anyone help?
Hi There
I have found this for to read and hope this will help you. Let me know how it goes.
The clock stopped The non-electronic clocks on electric range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need a user manual for smeg spa 42016 could you please advise where I can get one thanks
http://www.smegusa.com/user-manuals/
Search the Smeg site:
User manuals
SMEG USA, Inc.A&D Building
150 East 58th Street, 7th Floor
New York, NY 10155
Tel: +1 212 265 5378 / Fax: +1 212 265 5945
Mar 11, 2009 | Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Sep 09, 2007 | Kitchen Ranges
Smeg A42-5 Dual Fuel (Electric and Gas) Kitchen Range Logo
767 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
