Question about Behringer FBQ6200 Home Equalizer
Feedbacks theres this feedbacks i encounter, don't know to fix it, what is the best settings for the equalizer
It is best to use the feed back detection switch of your eq.,
Posted on Aug 02, 2008
  • andrew rex halina Aug 02, 2008
    it is best to use the feed back detection switch of your eq.,turn off the any sound then on ur mics then if there is feedback,the freq. that is lighting of the eq tells the freq. tha to be reduced.
Outlook has encountered a problem and needs to close
Google could've told you where to look for a solution.
Look here:
https://www.outlookrepairkit.com/
Also I can recommend you to run the scanpst.exe program
Sep 28, 2017 | HIS Computers & Internet
How do I stop feedback through speakers
Well, a feebackback destroyer is oke, or a good equalizer, no cheap noisy one and take one with 31 channeles /channel and lower the trequencies where about where you hear it lower frequency frequency by frequency, until you have the frequency which gives the problem and keep the frequency low in volume . But there are more ways, like replacing you monitors a bit. A low noise graphic equalizer ain't cheap. I thought ART has reasonable anti feedback surpressors....
Oct 07, 2014 | Philips 2.1 Multimedia Speaker System -...
Opal equalizer settings for conferencs
use eq to remove feedback, different settings for different rooms/environments. read, and experiment.
Mar 02, 2014 | Audio Players & Recorders
Mic feedback with numark c3fx
Feedback occurs whenever a microphone is being amplified, and it picks up its own signal above a certain level. Unfortunately, there's no way to reduce this possibility using just the Numark C3FX - you can only turn the microphone level down. The only way to reduce feedback through a speaker system is to use a graphic equalizer. Here's a good resource for how to do that: http://rfmedia.hubpages.com/hub/Controlling-Microphone-Feedback-with-a-Graphic-Equalizer
Nov 07, 2013 | Numark C3FX 4-Channel Rack Mixer With...
Lookin for user guide for technics sh-dv250
Just for sell: manualzone/do?model=M11375813
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 21, 2011 | Technics Audio Players & Recorders
Feedback
Supposedly one pushes down the FBQ button and the LED's in the EQ handles light for those with feedback and you adjust those till the lights go out.
More importantly I want to caution you to NEVER run this unit without a speaker load. There is an arc over condition in the rear-most power amp that kills the unit. This can happen even with everything connected. It causes major damage. At the slightest indication of flakey behavior, power down and take in for service.
Apr 02, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Best settings on a 13 band eq for rock and r&b
THAT IS BASE ON HOW YOUR SYSTEM IS SET UP MY FRIEND ADJUSTING ALL THOSE SETTING WONT GIVE YOU MORE BASS
Feb 11, 2009 | Kenwood KGC-9044 11-Band Car Equalizer
Feedback noise from mixer
Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Behringer FBQ6200 Home Equalizer Logo
135 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
