My equipment is a Panasonic Viera TX-L32X20B TV connected to an LG RC299H DVD/VIDEO Recorder.When I try to play a dvd disc I get the message:-"Unknown disc,please check disc and try again". I have no difficulty in playing a Video cassetta. Hope you can find a solution. Thanks DGH
  • hamdee87 Aug 02, 2010
    I would like a second opion. The previous solution is a little puzzling and needs some clarification as to the method of solving. thanks
    Yes, Taran's solution seems very promision. tell him he's a star. DGH
  • 10,515 Answers
First of all please clean the laser lens to see if it solves your problem.
1) Purchase a CD/DVD laser lens cleaner disc,
and run it through the system 5-6 times.You could easily get the laser lens cleaner disc from walmart.
2) purchase a can of compressed air .Open the CD tray or remove the cover of the player by removing the screws located on the sides towards the bottom and on the back towards the top. Then spray the can at a distance 10"- 12" from the lens to blow the dust away.
The compressed air can is available at walmart,amazon etc.
3)You can also use isopropyl alcohol, and a cotton swab to gently wipe the laser eye.
If all these things doesn't work then it is the laser of the unit which is at fault .You have to replace the laser to get everything back to allright.
Good Luck!!
Thanks!!
Posted on Aug 02, 2010
    Dear Taran, Thanks for the explanation. The recorder was purchaser in September 2007 but was not used much because of this fault. Regarding cleaning the lens. Would this require a special disc designed for the purpose ?. As for replacing the lens ! I reckon replacing the machine would be a better proposition. Wot say. DGH.
  • taran_2005
    taran_2005 Aug 02, 2010
    Thanks for your response!!
    Yes, you need to purchase that disc. It is easily available in the market. You could check with radio shack or fry's. Again, it is NOT a guarantee that it would fix the issue. It is only a trial. Yes, replacement is the best option as cost of repair would be high.
    Good Luck!!
    Thanks!!
  • 6,993 Answers
the fault is from the lens of the DVD player. The lens is weak that's why it not recognizing any disc.
Use a lens cleaner to clean the disc and try again.
Good luck.
  • Walesarumi
    Walesarumi Aug 02, 2010
    I mean, you a lens cleaner to clean the player. If that doesn't solve the problem, the is means the lens is weak such that it cannot be revived. In this case, you will have to replace the lens completely.
    Also, how long have you been using this player, the lens is weak/defective and needs to be replaced in order it to load DVD discs again.
    Take care.
Viera TX-26
Did He record the DVD for you???? or is it a store bought, if it is a store bought take it back if he made it for you then tell him to do it again and close the session for playback on a TV
Mar 17, 2014 | Panasonic Televison & Video
Panasonic Viera TX-L32X20B no channel found
the problem looks like bad main board , try to do the auto program , and see if it works , if dont work main signal board need to be replace
Feb 07, 2012 | Panasonic Televison & Video
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Sharp dvd and Panasonic tv not compatible?
thats got to do with the dvd aswell as the player, most dvds are locked to specific regions, the only suggestion i have is to get DVD X Player Pro for the pc since that will let you play and region dvd on your pc no matter what the drive is locked to.
Dec 25, 2008 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Jun 10, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
