Question about SkyGolf SkyCaddie SG4 GPS Receiver
SG4 will not accept a chargesa. Suspect a bad battery.
I cannot charge my SG4. The battery is about 3 years old.
  • jperdido Aug 02, 2010
    I am unable to charge my Skycaddie SG4. The battery is about 3 yaars old
  • 10,515 Answers
There could be many reasons. Few people have found the cable to be at fault. Few found charger and some battery. So, if you have any other charger and cable, you could use to make sure that there is no fault of charger or cable.
Then, you could check battery. If have a spare one, swap it unless using a multimeter check the continuity.
Other than this, it could be a hardware failure for which you need to senf the unit for repair.
Good Luck!!
Thanks!!
Posted on Aug 02, 2010
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
Ndrive g800r battery charging
Li-ion battery packs in laptops have a circuit board that prevents overcharging. Unfortunately it also keeps count of the number of times the battery pack has been through a charge/discharge cycle and eventhough the batteries maybe still be good; IT keeps batteries from accepting a full charge and and that is why they will not keep a charge for as long as they did when new. Also if any battery in the pack goes bad it effects the whole pack because of the way they are assembled.
May 19, 2017 | Computers & Internet
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
The starter on my 2000 sportster 883 is acting up. Bike hasn't been started in 6 months. Cranked great several times, but would not start. Battery is 3-4 years old, but was cranking strong. Starter clicks,...
I suspect the battery. Take the battery out and take it somewhere that they can do a "load test" on the battery. It's never good to just let a battery sit. When you let the battery sit without a "smart charger" on it, the charge bleeds down and the plates in the battery start to deterioate. Then, when you try to get it back by charging, you find that one or two cells are bad. The the bad cells will also prevent the votage from a jump starter from going through as well. Check the battery first, if it's 3 to 4 years old, it probably needs replacing anyway. Most motorcycle batteries don't last much longer than that unless they are premium grade batteries.
Good Luck
Steve
Mar 17, 2011 | Harley Davidson XLH Sportster 883 Hugger...
My garmin iq 3600 has died I left the gps antenea put and it will n0t take a charge.garman has stopped repairs on this model
I suspect that your Lithium polymer battery is going bad. If the battery is more than two (2) years old, then the ability to hold a charge has depleted and it will be gone after about three years total. You probably need to replace it. see: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+360&Show=ExtInfo&gclid=CPy2jceQ26UCFdk65QodMmeTyQ
for a possible replacement, or go on line and search for your particular battery model
Dec 07, 2010 | GPS
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
Razor stopped red light comes on will not charge
mcdevito75 here, If the battery is 2--3 years old it may have to be replaced, battery may not accept a chatge anymore. Look for any appliance repair shop in your area for assisstance. Sometimes with Norelco shavers it pays to replace the shaver over changeing the battery--ies.
Jun 25, 2010 | Norelco Spectra 8865 XL Electric Shaver
Toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Feb 12, 2010 | Toshiba Satellite A40-S270 Notebook
My wife's 1995 Buick Regal has no power
Sounds like a dead cell/shorted battery. 3 years is a little soon but with the fact that you recently replaced the alternator, I would suspect that your battery is done! Even a weak battery will let you jump one, bad cables usually will let you jump one, but a shorted/bad celll in a battery will prevent them from taking a jump. good luck
Jan 31, 2010 | 1995 Buick Regal
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
SkyGolf SkyCaddie SG4 GPS Receiver Logo
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
