Question about Muratec M1250 Fax
NOT ABLE TO SEND FAX WITH ADSL LINE
I HAVE A MURATEC M 1250 FAX MACHILE, IT WORK GOOD UNTIL I CHANGED MY TELEPHONE PROVIDER FROM A NORMAL LINE TO INTERNET ADSL LINE, I NOTE THAT AT MY NEW PROVIDER THE SYSTEM NOTES THAT THERE WAS A OUT GOING FAX BUT THE MACHINE DOS NOT THAKE IN THE PAPER.
AFTER ABOUT 40 SECONDS THE LINE DISCONECTS WITH A NOTE TRANSFER AGAIN AND ON THE REPORT THE RESULT IS T.2.1
    Genius:
  • 1,218 Answers
Can you pick up the handset and dial a number and speak to the other person using the handset..?? You might just require a filter which your telephone company should be able to provide.
Posted on Aug 19, 2010
Error code 388
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Sep 09, 2013 | HP FAX 1250 Fax Machine (Black)
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
Does Your DSL filter work for any analog modem attempting to send a fax (via fax software) using a DSL phone line?
Hello, Thanks for allowing me to help.
Sending a FAx over a telephone using adsl can be tricky, using a filter will help but you might want to make sure your baud rates are low, TRY 9600 baud, if you get any higher then that your filter might not filter it out and thus confusing the adsl connection.
I know mine works fine, make sure your fax is plugged into the TELEPHONE side of the filter!
I use 9600kbps , I do not recommend going any higher then that.
If that does not work you going to need to try another filter, last but not least call the telephone company if you are loosing connection.
Thanks for the questions, I hope my answer was Very Helpful.
Regards
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 25, 2011 | Zoom 98207 Adsl Filter Analog/DSL/Cable...
Muratec F-110 fax machine can send faxs but does not receive, i tried different phone lines, changed configurations changed toner, drum. nothing seems to work thanks, rick
Make sure the machine is in Fax mode and NOT Tel mode. Other thing to try is to pickup handset and listen to see if you hear "Dial-tone" from the line...if you don't then you have probably lost part of the NCU pcb in the machine.
Oct 05, 2010 | Muratec Office Equipment & Supplies
Error #252
This is a poor fax line error. The line quality has noise or some issue causing the fax receive /or send to fail , often people use the same line for faxing and ADSL (telephone provided internet) and this will cause noise on the line. To fix this I have used a noise filter that came withe the DSL router from the Telco. sometimes ive even had to use two, one on each end of the phone cable before the line was clear enough to send and recieve faxes without a problem. If this is not your case, have the person sending the fax do one at a time or vice versa. Hope that helps you Gurvy
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Error 351
  • The following is for error code 351
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed.
Mar 01, 2010 | HP FAX 1250 Fax Machine (Black)
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
Muratec mfx1430 fax problem
To determine if the problem is your 1430 or not.....remove the machine to another location....YOUR HOME; or a friends business where you can plug the machine in and test it. Have someone other than the person who you are having the problem with send you a fax. Once you know its your machine or not you can proceed from there.
Sep 12, 2008 | Muratec Copier
Can't fax
i could help ya with your problem
Aug 08, 2007 | Lexmark X4270 All-In-One InkJet Printer
Muratec M1250 Fax Logo
57 people viewed this question
Top Muratec Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Scott Yeoman
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
