Question about Kitchen Ranges
My Maytag Precision Touch Control 800 won't turn on. The burners and broiler work but not the oven. Any ideas?
reg501
  • 413 Answers
SOURCE: Maytag oven not heating up
The igniter has failed. In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve.($50.00 to $90.00 for igniter). The igniter can get hot enough to raise the temperature 100 to 120 degrees without activating the gas valve.
Posted on Jun 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Maytag oven doesn't light, broiler comes on instead
On some gas ranges, the broiler comes on with the bake selection during warm up. This allows the oven to preheat much quicker. More than likely, the control pad is functioning properly and your bake igniter is bad. Igniters become weak with age and eventually go bad. Since the bake feature is used more frequently, it typically goes bad more often. The following link provides you with some guidance on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Remember: just because an igniter glows, does not mean it is good. If they become weak, they will not draw the required current potential to open the gas safety valve.
If you determine the igniter to be bad, you can obtain a replacement at searspartsdirect.com. Just type in your model number and go to the "Gas Controls" heading and look for item number 14 (part number 74007498). If the igniter plug does not match the plug you have on your oven, the instructions will guide you to cut the wires and splice the ends together. There should be ceramic wire lugs that come with the igniter kit. CAUTION: Make sure you only use the ceramic (heat resistant) lugs that come with the kit. Splicing with regular wire lugs or electrical tape will melt due to the heat. Additionally, make sure you UNPLUG the appliance before replacing the igniter. Live voltage potentials are still present with the range shut off.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 11, 2008
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
  • 67 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
you need to replace the oven ignitor
micromaster
  • 3614 Answers
SOURCE: one burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Posted on Jun 02, 2009
Maytag precision touch control 500
Either both bake and broil elements are burnt out (highly unlikely) or your control / clock may be bad. Also check to be sure you have 220v going to unit.
Oct 02, 2017 | Ovens
I have a maytag gas range precision touch control 800 maytag model #MGR5875QDS. The top burners all work fine, the oven and broiler work only sporadically. I press to start and I get the flashing "bake"...
Good Afternoon!
What youre experiencing sounds like a power failure within the control board. I recommend sending in the control board (the clock where you see the time and temperature and connected membrane) into FixYourBoard.com for evaluation. We'll test the control to verify it is faulty before repairing. If the unit is bad, we'll remaufacture the part and test it again before sending it back to you. if the board is fully functional, we'll let you know. http://www.fixyourboard.com/how_to_ship.html
Each rebuild comes with a two year warranty. Don't hesitate contact us if you have further questions!
Jul 20, 2017 | Kitchen Ranges
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
163 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
