Question about Vacuums
I'm looking for an instruction manual for a Maxon MS 0720 power supply unit please
No steam or water even coming out, its just quiet except brushes moving
David, the brushes on the motor may be burned out and the conduction process has been compromised. In short the motor is bound up and won't turn. This can happen if surface debris collect on parts of the motor. Do not turn it on for long and let the unit get warm as it will eventually break down permanently.
If you need a manual, go the company web site and seek that from customer services.
Mar 10, 2014 | Bissell 46B4 Stick Steam Cleaner
Charger Specs
You can go to the website of Electrolux and put in the model and get a manual for the unit in question...in the manual it should give you the electrical characteristics of the unit.
Aug 28, 2013 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
I am looking for a copy of the basic user instruction manual for the Rowenta citrus press KA44
I'm glad to provide the manual for the unit. Please click hear to download the manual.
Please let me know if you require any clarifications.
Jul 01, 2011 | Rowenta Vacuums
Have no instruction manual for breville cappuccino maker vcf001 can i down load one please
Please try the appliance center where you get the unit. If they do not have, they could request from the manufacturer to mail or email you the instruction manual. Thank you for asking.
Jun 14, 2011 | Vacuums
I just adopted a Bissell 1719 spot cleaner from my sister-in-law but they don't have the manuals. How do I change the battery? I don't see any removable clips, just screws in the unit housing
Good evening,
Please see the below link for the user guide/manual to this unit:
http://www.retrevo.com/support/Bissell-1719-Vacuums-manual/id/10659bh140/t/2/
This unit should include a charger for the battery. Below is the instructions on how to charge and maintain the battery.
If you need to actually replace the battery, the instructions below show the process:
Just a quick note, these units do come with a Ni-Cad battery, which should last you at least 5 years (closer to 6 or 7), and make sure that dispose/recycle the battery properly.
This can all be found in the manual (link provided at the top). I hope this helps, and please let me know if you need clarification. Please rate this solution!
Thanks,
~PCF
Mar 15, 2011 | Bissell 1719 Spot Lifter 2X® Handheld...
Power button wont stay on. have to hold the power button manually for it to stay on.
Most likely you have to replace ON/OFF switch. look at detail instructions how to do it on our website:
http://www.goodvac.com/kb_results.asp?ID=18
If you need any parts or supplies for your Kirby sweeper you can find lowest prices on our website http://www.goodvac.com/. Everything is in stock and ready to ship same day.
Good Luck,
Rocky
Dec 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
112 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
