Question about APC Smart-UPS 3000VA UPS System
APC SmartUPS 3000VA
Hi, i'have an APC SmartUPS 300VA 220V (SUA3000I) that died due to lightning in the mountains.
i'm trying to repair it, but i need wiring diagram. do you have it?
i've not found a diode bridge, and i don't understand it.
The capacitor on 220V input C113 was broken.
The fuse (100A) on battery ground was broken also.
The rest of mainboard seems to be ok.
Can you help me, please?
Thanks
    Novelist:
  • 169 Answers
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Posted on Aug 02, 2010
APC Smart UPS 3000VA control panel cable short
Do you mean short circuit or that it is too short ??
Jan 12, 2015 | APC Smart-UPS RT 3000VA UPS System
Sua 3000xl all leds blingking
In My experience this was cause by welded relay, Please check the UPS relay if not check the UPS revision to International and change the incoming voltage, calibration value.
Jul 05, 2014 | APC Sua3000xl SmartUps Xl 3000va 120v...
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
Hi my APC smart 3000 UPS THE AVR boost LED IN ALWAYS ON. DO I NEED TO CHANGE THE BATTERY?
How many years the batteries working?
Usually every 4 years change the batteries.
Do you have power down often?
Feb 24, 2014 | APC Smart-UPS RT 3000VA UPS System
Service manual
www.service manuals.com.aspx/
Try this link.
Oct 23, 2013 | APC SMARTUPS RT 3000VA 230V (SURTD3000XLI)...
Apc 3kva ups is not working at 260 volts
try to do some calibration, but my question is why you need to plug the UPS on a 260 Volts??? which country you're from???
Nov 27, 2012 | APC SmartUPS RT 3kVA Rackmountable UPS ...
APC SMARTUPS 1500VA Battery Problem When Replaced
You are correct. The APC Smart line has a partial charge when it's new. Similar to cordless phones, the work right away, but you're still supposed to charge them before use for best results.
Just leave it plugged in with no load for a couple hours and it will be fine.
Sep 02, 2009 | APC Computers & Internet
Problem with SmartUPS SU5000I
Before trying to replace an IC, make sure that the battery is capable of holding a charge. If there is more than 1 battery, check all. If it (they) are bad, it will probably be less expensive to replace the unit.
Jul 24, 2009 | APC (SUA3000I) UPS System
APC 300 0 PROBLEM
Your inverter is blown on the ouput. If it is a 300VA get a new one, 3000VA, you will need a local UPS repar company.
Jan 14, 2009 | APC Back UPS 650 (APWBK650MC) UPS System
APC Smart-UPS 3000VA UPS System Logo
473 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
