Question about Humax 19 in. LCD TV
Mod - LGB-17DTTV. Fault - Vertical blue band approx 10 cm wide appears when set warms about 15 cm from the right edge of the screen. Picture can be seen through the blue, the line is present in AV modes and with no signal. Fault clears if set allowed to cool but returnes when warm. The line comes and goes and flickers at 1st but is constant once set is warm. Andy.
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
Vertical Band has appeared on my TH-42PX60B
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Feb 20, 2012 | Panasonic VIERA Televison & Video
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Vertical bands on screen
bad x drive board on bottom of set where lines appear
Apr 27, 2009 | Televison & Video
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
SCREEN PROBLEM WITH HITACHI 42DP8600
It is dry solder joints inside the tv. If you are going to do it yourself try these places for a fix: vertical scan board, focus board, line output board, chroma board. If you are not able to do this yourself then find a competant technician. Hope this helps.
Sep 05, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Intermittent Defect on LCD TV
If new, you should not remove anything, just send back to store or Manufacturer
Mar 13, 2008 | Philips Magnavox 27MS343S 27" TV
Humax  19 in. LCD TV Logo
73 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
