Question about Sony Ericsson K530i Cellular Phone
It's not working properly, i m facing charging problem. i think phone pins are damaged. please do the needful asap.
    Sergeant:
  • 129 Answers
Hi :) here i teach u how to solve your pro,if u check the phone charging port was dirty,u can use a tooth brush and some alcohol. brush the charging port.try it. normally sony have this kind of pro.
please voted me if my solution useful,thank..
Posted on Aug 02, 2010
Game file can not open
Posted on Nov 16, 2010
Remmington 700 new total of 12 shots action works and sounds perfect but missfires leaves no mark on the primer
tear down the action clean the parts look for damage on each easpecially the spring and firing pin, and also the ejector to make sure a round is properly seated against the face of the bolt, do the rounds eject properly?, you may need to order a new firing pin and or spring from the manufacturer, Remmington online, some manufacturers will send you free parts such as smith and wesson who desnt even charge shiping
Jan 04, 2015 | Optics
Im not able to charge my phone ! When plug in the charger it shows not charging stop! Wat should i do.... Please sugest me a way to get rid of this problem..please...!
There could be 2 reasons.
1- Charging pin of the charger is not working properly.
2- The point where you put the charging pin is faulty.
Apr 25, 2011 | Nokia 1112 Cellular Phone
My phone does not want to charge wats wrong
try with other charger.. if nt working den make sure d chargin pins on phone s proper... its a small hardware issue.. open d phone n make sure d charging socket on circuit has no damage... ( switch off ur phone n try charging too )
Jan 03, 2011 | Samsung Highlight Cell Phone
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
Hi, I have an Acer Aspire 5600 which has problems charging. I have recently replaced the power cord as the other one had broken. the charging pin that goes into the computer only works when facing a...
This is a common complaint of the wire shorting inside, please go to my tips page so that this particular complaint was reviewed with some tips.
The short within the wire cuts off the adaptor votlage as it is in protect mode-- not a failure of the adaptor. so have the wire **** off and connected or use a new pin at the end.
Oct 30, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
I need help replacing the Charge port on an Lg Shine.
you can take the phone apart again and gently pull the pins slightly out of the connector enclosure with a sewing pin. this could ensure proper contact due to the metal's elasticity (would have them act like a spring)
Aug 31, 2009 | LG Shine KE970 Cellular Phone
Battery Wont Charge
either the battery is drained so its not getting charged. remove the battery from the cell and check out.or the charger is faulty so need to replace the charger.sometimes pressing the pin of charger in to the cell gets connected internally and the charging starts try it.other wise that two above things need to be checked.
Mar 02, 2009 | LG ALLTEL AX275 Cellular Phone
Touch Screen
when i buy phone after some days. that is no working. so please give me solution
May 21, 2008 | Motorola Mobility ROKR E6 Smartphone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Sony Ericsson K530i Cellular Phone Logo
134 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
