Question about Dryers
It will trun on but will not run. You can set the controls and hear a click and then it will just go though the mode with the lights and never trun the drum.Brand New
  • Dryers Master
  • 1,527 Answers
Hello make sure the long pin that sits inside the door is connected this makes the motor turn if ok the it could be the capacitor next to the motor in side the dryer also check the belt it may snaped good luck
regards
shaun
Posted on Aug 03, 2010
Refrigerator not cooling; Freezer not freezing.
first do u hear the compressor running? any clicking sounds? cold control may be bad? stuck in defrost mode? do u hear the fan running? u can manually take it off defrost mode by placing a small philips screw driver into the tiny hole underneath it the ( cold control thermostat), and turn it slowly till u hear one click this will take it off the defrost mode. if ur problem is the cold control. if that does not work u may have a bad compressor relay and can do a 3 in 1 hardstart and it should kick back in and work agin
Mar 10, 2015 | Refrigerators
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
2003 Mercury Mountaineer Electrical Problems?!?!?!
O/D light flashing is telling there is a problem with the transmission an trouble codes are stored . The clicking you hear in the rear climate control system is mode door or blend door actuator . There is no accumulator in the rear A/C system . If the A/C system had a accumulator it would be in the engine compartment . Your best bet ,take it to a qualified repair shop.
Jul 13, 2017 | 2003 Mercury Mountaineer
The beeps start slowly then get faster and faster - it beeps for over a minute then stops. 5 mins later it does it again, then again. then nothing more until say the next day. The console is is standby...
i think there mite be som problem with settings...did u use any unauthorised cds or internet program...or u mite used it for a long time..u try this site to solve your problems click hear
Nov 04, 2010 | Sony Playstation 3 (PS3) Console
The red light is always on in my humidifier control panel. When I set it to test, I hear nothing clicking. No water runs into my humidifier. The unit (model 600) is about 6 years old.
if your using an outdoor thermostat then it may not be connected properly or the manual mode resistor wires are touching. these are connected on the humidistat just to the right of the H H terminals
Dec 12, 2009 | Aprilaire 600 Humidifier
Popping sound from near glove box in dash in 2008 Impala
This is the location of your BcM or Body control Mod. This controls all the things you are talking about. Lights, flashers,door locks trunk lock, that clicking you are hearing is a relay turning something on. So Lets say you are driving and it starts to get dark your BcM will change your driving lights to full night time mode, turning lights on, on your dash. Now you have Bright and dim functions. There is a sensor in the dash up front in the windshield that senses dark/light and does this. That is what you hear, a relay in your BcM clicking off/on some function of the car.
Aug 13, 2009 | 2008 Chevrolet Impala
Can not see my subject through the lcd screen
I believe that the "LIVE VIEW" shooting can only be done in Auto mode. Once in Auto mode, try pressing the SET button located to the right of the LCD screen. Once depressed, you should hear a quick click noise and see what the lens is seeing on the LCD screen. Click on it again and it should revert back to "viewfinder" mode.
I Can Fix It
Jul 10, 2009 | Canon EOS Rebel XSi Digital Camera
Jacuzzi hot tub will not shut off
I take it for granted that you know when the tub is in cycle mode for water circulation, ( the tub will do this every 4 to 8 hours unless programed otherwise). If it is truly going into the low speed on the pump, the problem lies in the circuit board. The double click you hear is the relay for the pump turning off and then on again. This is a costly problem to diagnose as circuit boards start at 200.00 and go up. If it is the relay, the only way to replace one is to replace the circuit board.
Jul 03, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Settings
you will want to turn your radio volume up till you hear distortion then trun it down slightly. then turn your amp up until you hear distortion then trun you amp down slightly.
Aug 06, 2008 | Alphasonik PMA600HC Car Audio Amplifier
Dryers Logo
29 people viewed this question
Top Dryers Experts
Marvin
Marvin
