Question about AEG Dishwashers
My SEG Favorit sensorlogic dishwasher model 54730 seems to be stuck in 70 intensive cycle, not sure if someone started this cycle by mistake. how can i reset it so i can start from scratch again?
4 Suggested Answers
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Posted on Jan 24, 2010
  • 174 Answers
SOURCE: Our AEG Favorit Sensorlogic dishwasher has had no power to it
if u just reinstalled mke sure you removed the blancking plug from the drain spigot . simple but happens a lot.
Posted on Jul 22, 2010
AEG Dishwasher 60820 Sensorlogic Delay timer stuck on 1Hr
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
However if the senslogic (pc board) has a program fault, the cost of this board = half the cost of a new washer ......
Apr 13, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
My AEG favorit sensorlogic turbo dry dishwasher keeps bleeping and want start. Im not sure whats wrong with it. I have cleaned the filters and put in new salt and it still wont work. The programme...
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Jun 09, 2008 | Dishwashers
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
83 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
