Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Need to change water pump on 3600 tractor. how do i get to it, what comes off. need pictures
We changed water pump in Kubota l3010 tractor. It won't crank and water is coming out of exhaust pipe. Any suggestions?
Jonsas, right. Don't try to crank with water on pistons. If it crank, it would bent the rods. Pull spark plugs or injector precups first.
Mar 30, 2015 | Kubota Garden
Lift system isnt working and pto shaft dusnt rotate when activated
The pump may be bad or need bleeding out.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 17, 2010 | Ford Tractor Grill 2600 3600 4600 5600...
Hello, I need to remove the steering wheel on my Ford 3000 tractor.It seems rather stuck after 40 years.Are there any threads inside it or is it suppose to be pulled straight off? regards AD
Hi AD, I had the same dramas with my 3600. I had a steering wheel puller but found nowhere inside the wheel to put any bolts in, so I used 3 "D" shackles and short chains around the steering wheel spokes to the puller hub, added LOTS of WD40 then wound the puller breaker bolt in until the spokes started to bend with tension. (Sounds pretty rough but I had no other option). Everyone I asked about the procedure insisted that there were bolt holes in the hub of the steering wheel for the puller but in our instances, there are none. I also used a piece of hardwood with a fork cut in it to fit around the steering shaft (removed the trafficator arm first) then bashed it upwards with a mallet until it came free. IMPORTANT NOTE> leave the steering shaft centre nut on the end of the thread to avoid having the steering wheel smack you in the chops when the wheel comes free. Best of luck,
Errol
Mar 29, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
What do i need to torque ford 4000 cyl head bolts down to
my ford 3600 head bolt torque settings are a 3 step tensioning sequence. 90 ft lbs then 100 ft lbs then 110 ft lbs final torque value.
Mar 22, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
I need to know if the pulley for the water-pump on a 245 massey furguson (diesel) comes with the new water pump or can i remove pulley from shaft of water pump.
remove pulley with pulley puller, u can rent it for free from auto zone/part supply store. if it comes with new pulley dont worry bout it :)
Sep 14, 2009 | Garden
Honda water pump
normally all the water pumps coupled with portable gas powered engine have 3000 - 3600 rpm
May 19, 2009 | Honda 8 HP Engine
Savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Apr 06, 2009 | Savio Water Master Solids Handling Pond...
A lot of water remains in machine at end of wash cycle
The drain pump might have gone bad, check if the drain pump is making some kind of noise and also check if the drain pump is not obstructed.
You can open the coin trap on he right hand side bottom of the unit and clean the same for any blockage.
Nov 27, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
115 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
