Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Hi, I have this Verbatim store'n go 8GB flash drive...suddenly I cannot write to it or delete files from it. I can only copy out...I have tried to format with many formating tools and it keeps saying "The device is write protected.I tried regedit...cntrol device nothing can fix this bloody thing can somebody please help.It is product no. 43991. Thanks Napo
  • Verbatim Master
  • 27,725 Answers
Click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Posted on Jan 09, 2012
  • 547 Answers
Do you have verbatim's "V-Key" driver for this flash drive?
If so, there's an option in that driver for "write-protect enable" and a checkbox for that option.
If not, and it's operating as a standard USB mass storage device, then you can try this registry change:
- Start > Run > type ‘regedit’ then hit 'OK'.
- Browse to the following key:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- You may also need to do this for the strings in any folders called ‘ControlSet***’ e.g.
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolicies
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\StorageDevicePolicies
etc.
Posted on Aug 02, 2010
8gb flash drive holds less than 2gb
Try reformatting the flash drive. Copy all your important files somewhere, since reformatting the device would erase all saved data. Go to "My Computer", right click on the usb device, click "Format...", click "Start" on the window that pops-up, click "ok" and wait for the formatting to finish. This should erase all data on the device, including hidden files that might be taking the space up.
Apr 28, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
I have purchased an 8GB TDK and unfortunately when I delete the files and try to add new ones, I receive a message that there is not enough free space. I am using a Mac. What should I do!!!! Ian.
Try to format the USB flash drive Then you will clear it of al the files it has, if you don't want to lose the files, copy them into your computer, and copy them back after the formatting is complete, after formatting, I'd suggest you'd see the properties of the flash drive, to see the memory and the occupation of the memory, from time to time.
Apr 25, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Verbatim 2 GB store n go says it has 918 MB of free space, but says 'disk is full' when I try to add files. I do not believe the store n go is partitioned. What gives?
If you can read the drive, Copy the information from it, into your computer, and format the drive, copy the files back, and it should work... also, if you have a security switch on the drive (write protection) you have to disable it.
Apr 14, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
VERBATIM 8GB FLASH DRIVE CANNOT FORMAT. FILE SYTEM UNKNOWN.CANNOT DELETE FILES ON DRIVE
Hi, try going into 'Control Panel' -> 'Administrative Tools' -> 'Computer Management'
Then, under 'Storage', choose 'Disk Management' and try formatting from there. If necessary, give your usb key a drive letter.
Mar 07, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
How do I use this product? How do I select and copy file to the USB flash drive?
Plug it into the usb port and go to 'my computer' there you will se the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Jan 18, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
NOT RECONISING THE PEN DRIVE-Verbatim ® Store
try a usb port on the back of the computer, if not the drive could be faulty
Jan 03, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
8mb vs 8gb of space on an 8gb flash drive
sounds like you upgraded it to a dynamic volume and are using the leftover space, flash drives should be left as basic disks and formatted fat 32.
Mar 15, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
Nov 19, 2009 | Verbatim Electronics - Others
My flash drive verbatim 8 gb store and go is not recognized
I looked into similar problems and if this works ill let you knw i downloaded Paragon Pation Manager and i plan to use this to create a 8gb partion on my flash drive i dont know if this will work but ill get back to you
Nov 05, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
526 people viewed this question
Top Verbatim Computers & Internet Experts
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
