Question about Refrigerators
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit, however, it iwill only work on gas if plugged in or hooked up to a generator. We are desperate. Any ideas what it MIGHT be that could be wrong?
  • Refrigerators Master
  • 8,404 Answers
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Posted on Aug 02, 2010
  • breed121 Aug 03, 2010
    yes, we have a battery and it is testing all over the camper that the full 12 volts are there! (info from the hubby) we do not have electric on the site for a week. that is why we had to borrow a generator, however, can only run a few hours per day. IT definately cools if running on a generator, however, as soon as we stop it the flame goes out for the lp. :( So not sure at this point what is truly the problem. My husband works on construction and electrical and it has even himself baffled. He called someone today that is suppose to be coming to look at it and he also said he never heard of such a thing :( It wont run though on anything other than LP, even if plugged in at home, wont run on electric or auto, only lp.
  • A Miller Aug 03, 2010
    You say you are certain you have 12 volts available and I will accept that you know what you are talking about. I stand by my guns ... if you have 12 volts DC and gas, the frig must work. I suggest you verify the 12 volts where it goes into the frig control panel. Also, check the volts on the battery, with the cable disconnected.
    I hear what you are saying. It will run on gas if you have 110 - there is something missing ... this isn't how the design is suppose to work. If the frig finds 110, it is suppose to use 110. In the absence of 110, the 12 volts DC is suppose to turn on the gas and light the flame. Norcold or Dometic ... same same (basic system wise).
    Here is the next thing to try, (when you get home where you have a steady and reliable 110 volts AC), find the leads for the CalRod and wire them directly to 110 volts (you will likely find them curently plugged into to the control panel) They will look similar to lamp cord and there will be two and they will lead up into the boiler section. You can turn the frig 'off' at this point. If the CalRod is good, being wired directly to 110 volts, it will heat up and cause the NorCold to work. Check after a few hours or after a day. If it is cold, your CalRod is good. If your frig is not cold, your CalRod is not working and that is why it will not cool on AC power.
    When a control panel quit on a Norcold I had, rather than pay the big bucks for a new panel, I just hot wired it and it ran fine for the rest of its life (about 8 months) when I replaced it with another Norcold. Of course, it wouldn't run on gas durig that time.
    You might have something else going on in the control ... but what I am suggesting is pretty basic stuff. If you apply heat (via flame or electricity) to the ammonia solution, and the solution is able to travel through the system, the system must work - it is the law (physics).
    As the facility manager at a camping resort, I do encounter some strange things in absorption frigs. I am not a frig mechanic. However, when I apply the logic I have outlined above, generally, the problem is resolved. A blown fuse or a loose connection or a valve turned off ... I am very interested to learn of what you eventually find with your Norcold.
    Thanks
My Norcold N611 RV fridge freezes everything in the fridge even on the lowest setting. My husband changed the thermostat control board last year, but this did not correct the situation. He wanted to try moving the thermostat on the fins inside the fridge. Should it be placed lower or higher on the fin so the temp doesn't get so cold
Posted on Aug 03, 2010
    It doesn't make much difference where the probe is located on the fins. Some newer friges don't have adjustible temperatures ... they are fully 'automatic', like it or not.
    Thanks
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
My Norcold model 663. Is not switching to AC.
When gas is leaking, first fridge will stop working, than the freezer. I hope you dont have gas leaking. Is the compressor running all the time?
Dec 03, 2017 | Refrigerators
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
762 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
