Question about ACCPAC Simply Accounting 2004 PRO (2120148) for PC
When opening for entries for 2010, I incorrectly entered January 1, 2011 as my new session date. How can I now change this back. It will not go back into the year 2010 when I ask to change session date. I am working with Simply Accounting 9.0 version
You would have to restore a backup that was made prior to advancing the session date too far.
Posted on Aug 03, 2010
Replace battery and still cannot solve the date and time problem?
you might have to install another cmos battery the one you have might be bad
or you might have to change it to 24 hr time then revert it back a few times for the computer to realise the change
hope this helps
Sep 23, 2012 | Intel Desktop Board D815EEA2 Universal...
I need to set date and time on the 6110 all in one printer
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 37 of the ONLINE USER'S MANUAL for detailed instructions on how to SET THE DATE AND TIME.
Basically it reads as follows:
Press MENU.
Press 5.
Press 1.
Then enter the last 2 digits only of the MONTH, DAY, and YEAR using the keypad.
Then enter the HOUR and MINUTES.
Then press 1 for AM or 2 for PM.
Then press 1 for OK if required.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Apr 14, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HOW TO SET DATE & TIME
To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
Press the "SET" button 2 times until you see: USER SETTINGS - 1. DATE & TIME.
To open the DATE & TIME Menu. Press SET. Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR. Press SET to "lock in" the Date and Time.
These instructions come directly from the User's Manual.
Hope this helps.
Mar 29, 2011 | Canon L220 Plain Paper Laser Fax
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Aug 24, 2010 | Victor 1560-6 Calculator
My Notebook time and date is always returned back to January 10, 2010.
Set the time inside Windows..If this will work..Go to the BIOS and manually set the time..If this will not work..You need to purchase a new CMOS for the Computer..CMOS is faulty..
Feb 03, 2010 | Microsoft Windows Vista Business Edition...
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
3. To open the DATE & TIME Menu. Press SET.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
I need to change payment date on entry
check on entry number of the item you need to amend/click on File/maintenance/corrections/ find number and view entry/amend date and save
Jul 06, 2009 | Sage Instant Accounts 8.0 (013604ug)
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Unable to change today's date on new Samsung SHG-D980
To change the date select:
menu, settings, time and date.
Drag down the screen until you reach the Date box.
press once, press a second time.
enter the date and press OK
save and exit
hope this works, it worked for me and I had exactly the same problem.
Feb 24, 2009 | Samsung SGH-D980 Cell Phone
Pro Star DCS 24 B
SYSTEM ADMINISTRATOR
PROGRAMMING
SET DATE AND TIME DISPLAY Should it become necessary to correct the date and time displayed on all of the keysets, due of time change (twice a year), you must first access the customer programs.
To access customer programs, open system programming using the passcode you have been assigned. (Default passcode is 1234). You must use a (display phone) LCD 12B or LCD 24B keyset. ENABLE CUSTOMER PROGRAMMING topbul1a.gif While on-hook, press TRSF and dial 200. he display shows. ENABLE CUS. PROG.
PASSCODE
: topbul1a.gif Dial the four digit passcode. The display shows: ENABLE CUS. PROG.
DISABLE
topbul1a.gif Dial 1 or press the ▲ on the Volume to enable. The display shows: ENABLE CUS. PROG.
ENABLE
topbul1a.gif Press TRSF. The keyset returns to its idle condition.
The display format is the following:
W (Day of the week): Enter 0 for Sunday and 6 for Saturday.
MM (Month): Enter 01 for January and 12 for December.
DD (Day of the month): Enter a number in the range of 01-31
YY (Year): Enter the last two digits of the year.
HH (Hours): Use the 24 hour clock and enter a number in the range of 00-24.
MM (Minutes): Enter a number in the range of 00-59.
SETTING THE DATE AND TIME 1. Press TRSF and then dial the 505. The display shows: OLD: 1102802:0852
NEW: WMMDDYY:HHMM
2. Enter the new time and date using the above format: OLD: 1102802:0852
NEW: 1102802:0752
3. Verify the time and date and reenter them if necessary OLD: 1102802:0752
NEW: WMMDDYY:HHMM
4. Press TRSF to store and exit programming.
If you have entered invalid data, you will receive an [INVALID ENTRY] message for three seconds. Reenter the correct date and time. If the information you entered is incorrect, repeat steps 1 through 4.
Aug 04, 2008 | Samsung Prostar DCS Phone
ACCPAC Simply Accounting 2004 PRO (2120148) for PC Logo
104 people viewed this question
Top ACCPAC Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Marvin
Marvin
BJ Russell
Are you an ACCPAC Computer and Internet Expert? Answer questions, earn points and help others
